Prior to receiving airworthiness certification, extensive testing is required during the development of rotary
wing aircraft drive systems. Many of these tests are conducted to demonstrate the drive system’s ability to operate at extreme conditions, i.e. — beyond that called for in the normal to maximum power operating range.
Developed here is a new method to automatically find the optimal topological modification from the predetermined measurement grid points for bevel gears. Employing this method
enables the duplication of any flank form of a bevel gear given by the measurement points and the creation of a 3-D model for CAM machining in a very short time. This method not only
allows the user to model existing flank forms into 3-D models, but also can be applied for various other purposes, such as compensating for hardening distortions and manufacturing deviations which are very important issues but not yet solved in the practical milling process.
Beginning with our June Issue, Gear Technology is pleased to present a series of full-length chapters excerpted from Dr. Hermann J. Stadtfeld’s latest scholarly — yet practical — contribution to the gear industry — Gleason Bevel Gear
Technology. Released in March, 2014 the book boasts 365 figures
intended to add graphic support of a better understanding and easier recollection of the covered material.
Alongside the macro test parameters on tooth flanks for profile and tooth traces, surface
properties (roughness) play a decisive role in ensuring proper toothed gear function. This
article addresses roughness measurement systems on tooth flanks. In addition to universal
test equipment, modified test equipment based on the profile method for use on gears is
addressed in particular. The equipment application here refers to cylindrical gear flanks and
bevel gear flanks. The most important roughness parameters, as well as the implementation
of the precise measurement procedure will also be described under consideration of the
applicable DIN EN ISO standards as well as the current VDI/VDE Directive 2612 Sheet 5.
This paper presents the geometric design of hypoid gears with involute gear teeth. An
overview of face cutting techniques prevalent in hypoid gear fabrication is presented. Next,
the specification of a planar involute rack is reviewed. This rack is used to define a variable
diameter cutter based upon a system of cylindroidal coordinates; thus, a cursory presentation
of cylindroidal coordinates is included. A mapping transforms the planar involute rack into a variable diameter cutter using the cylindroidal coordinates. Hypoid gears are based on the envelope of this cutter. A hypoid gear set is presented based on an automotive rear axle.
This paper proposes a new method — using neural oscillators — for filtering out background vibration noise in meshing plastic gear pairs in the detection of signs of gear failure. In this paper these unnecessary frequency components are eliminated with a feed-forward control system in which the neural oscillator’s synchronization property works. Each neural oscillator is designed to tune the natural frequency to a particular one of the components.
