Bonfiglioli 300 Series Designed for Harsh Applications
Bonfiglioli´s 300 Series is designed for harsh applications where shock loadings and impacts are common.
Bonfiglioli´s ongoing mission to improve its planetary gearboxes for industrial applications has led to two new features that result in an easier and safer assembling/disassembling of the drive to/from the application. The new FDK and FZP versions feature an output hollow shaft that will make the series more effective and suitable for shaft mount assembly.
The hollow shaft solutions reduce the time and effort for the disassembling of the drive from the customer´s machine shaft, due to the new solution with the axial locking ring. The new product solutions make mounting and commissioning easier and faster thanks to the smarter design and allow for easier and more accurate screw tightening.
Furthermore, the cutting-edge design of the shrink disk will improve and speed up setup and commissioning. The hollow shaft with the two keys at 120° will allow full rated torque and max torque transmissions. The axial locking ring with threaded holes completes the solution for an easier and more reliable shaft mounting. They keyed hollow shaft is available in smaller sizes, ranging from 300 to 310 and will be included in the designation of the series with the acronym FDK; when the FZP version is available it will come in larger sizes from 311 to 325.
Another design component of the new 300 series is the splined hollow shaft which meets the DIN 5480 standard and offers the same bearings available in the current FP version. It provides double centering for an aligned assembling of the solid shaft of the machine. Like the keyed hollow shaft, the splined hollow shaft also includes an axial locking key with threaded holes for easier mounting and grants full rated and max torque transmissions.
The new shrink disks prevent accidental mounting errors (even when dismounting and re-mounting the shrink disk) due to simpler design and visual-control of screw tightening torque. This design makes the 300 series now complete and effective for any shaft mounted requirements for all sizes and ratios. The series has a torque range of 1,000-1,287,000 Nm and gear ratios of 3.4-5,234. Bonfiglioli´s new 300 series offers customers a more flexible solution due to its ability to adapt to client and application requirements and provides more control during the mounting process.
