Design Corrections Flank Correction Optimization Technical Helical Gears
Calculation of Optimum Tooth Flank Corrections for Helical Gears
The load carrying behavior of gears is strongly influenced by local stress concentrations in the tooth root and by Hertzian pressure peaks in the tooth flanks produced by geometric deviations associated with manufacturing, assembly and deformation processes. The dynamic effects within the mesh are essentially determined by the engagement shock, the parametric excitation and also by the deviant tooth geometry.
This article appeared in the September/October 1988 issue.
