The newly designed, multi-functional FNL-220LSY Series multi-axis lathe incorporates many innovative features.
Turning and milling with first and second operations are in one machine. Y-axis travel (+/-2.2" from the centerline) for off-center milling is the largest range in its class. The series features high-torque live tooling, with full C-axis for the main and sub-spindle. The ability to turn and mill complex parts and perform multiple operations on one machine increases throughput and reduces handling. And the machine is superior to the competition with a competitive price.
The bar capacity is 2.0" for main spindle, maximum cutting diameter is 12.6" with a turning length of 20.1". The swing over bed is 24.4". chuck size is 8" for main spindle and 6" for the sub-spindle. The travel distance on X, Z, Y and C1-C2-axes are 8.7" by 22.0" by 4.3"(+/-2.2) by 360-degrees with a rapid traverse rate of 1,181ipm. Sixty-degree, compound Y-axis, slant bed design with roller linear ways. Linear roller guide ways ensure the highest accuracy during high-speed machining. These guide ways provide 30 percent stronger rigidity than regular ball ways. German Sauter, 12-station BMT-45 live turret with maximum 4,000 RPM live tooling speed with all stations live, is standard for this series. An oversized clamping curved coupling enhances rigidity and accuracy of cutting tools during machining. Hydraulic clamping cylinder with a disk break to ensure the rigidity for heavy-duty milling and full C-axis in both spindles with a minimum interpolation of 0.001 degrees. FANUC 0i-TF control with FANUC drives and motors plus 10.4" color LCD with a fully conversational Manual Guide i program and 3D simulation. Standard accessories include chip conveyor, parts catcher, oil skimmer, tool presetter, turning holder package, rotary holders package and more.
FSG-2440ADS Fully Automatic, 3-Axis Grinder
Chevalier is introducing the FSG-ADS Series, a high-precision, fully automatic, 3-axis grinder with a PLC controller. The cutting-edge device provides a grind cycle with rough grinding, fine grinding, spark-out passes and an automatic over-wheel dresser with compensation, which can be added to fully automate the grind process. After the cycle is finished, the table will "park" either left or right of the saddle and at the front to facilitate unloading and loading.
The series, which is well suited to mass production and easy to set up, program and operate, features user-friendly conversational programming. The machine's spindle can be set to "stop running" or "continue running." The wheel head can also be set to return to the start position or to park at a reference point. Once the cycle is started, the wheel head moves rapidly to the start point and repeats the grind cycle. If material is required to be removed from both sides, "flip over" can be selected, leaving the wheel head position at the finish grind height, which then starts grinding immediately without touching off.
The fully automatic grind feature consists of rough- and fine-grinding cycles, switching from rough-grinding down-feed increments to fine-grinding down-feed increments at preset points during the cycle. The crossfeed also switches from a rough to fine cross-feed increment, resulting in a finer surface finish and finer accuracy.
FSG-1632ADIII Fully Automatic, 3-axis Grinder
The new FSG-ADIII series is an advanced, automatic-precision, surface-grinding machine that offers improved accuracy, quality and ease of operation. This series includes a new touchscreen control station adjustable to a comfortable position for the operator.
"Switches, buttons, LEDs and indicating lamps are all combined in a touch display that is ergonomically positioned to provide the best user-friendly operation," says Chevalier vice president Johnson Lan.
The FSG-ADIII Series includes a new PLC controller that provides a grind cycle with rough grinding, fine grinding, spark-out passes and an automatic over-wheel dresser with compensation, which can be added to fully automate the grind process. After the cycle is finished, the table will "park" either left or right of the saddle and at the front to facilitate unloading and loading. The spindle can be set to "stop running" or "continue running." The wheel head can also be set to return to the start position or to park at a reference point. Once the cycle is started, the wheel head will move rapidly to the start point and repeat the grind cycle. If material is required to be removed from both sides, "flip over" can be selected, leaving the wheel head position is at the finish grind height, which will start grinding. immediately without touching off.
Smart-B818III, Smart-B1224III and Smart-B1640III Surface and High-Profile CNC Grinders
The Smart-III Series surface and high profile CNC grinders have received client praise for its high-precision grinding and ease of operation. The Smart-III is capable of producing "mirror" surface finishes on highly accurately ground workpieces with microfinishes of 5 RMS. The positioning accuracy is (+/-) 0.0025 micron; grinding accuracy is 1 micron. The Smart's movements are programmable in increments of 0.001mm and include a table size of up to 24" x 80". The maximum distance from table to spindle centerline on the Smart-B818III is 16"; the wheel spindle is rated at 500-7000RPM and 4HP (3kw). The Smart-B1224III and Smart-B1640III are both 24" and wheel spindles are rated at 500~3,000RPM and 15HP (11kW). The Smart's standard grinding wheel size is up to 16" x 3" x 5". The SMART's PC-based control, combined with a user-friendly conversational TaskLink function, makes it easy to learn and operate. Also, constant contact dressing programs are provided to increase the dressing efficiency.
