Design Gear Rating The Gear Industry AGMA Technical
Cutting Hardened Gears
The need for improved power transmissions that use gears and gearboxes with smaller overall dimensions and with lower noise generation has left manufacturing engineers searching for different methods of gear processing. This search has led to the requirement of hardened gears.
This article appeared in the November/December 2002 issue.
