Rick Miller
Design Calculation Equations Pressure Angle Technical Spur Gears
Designing Very Strong Gear Teeth by Means of High Pressure Angles
The purpose of this paper is to present a method of designing and specifying gear teeth with much higher bending and surface contact strength (reduced bending and surface contact stresses). This paper will show calculation procedures, mathematical solutions and the theoretical background equations to do this.
This article appeared in the June 2017 issue.
