Manufacturing Cutting Tools Carbide Processes Bevel Gear Cutting Dry Cutting Heat Treating Induction Hardening Tempering Features Bevel Gears
Dry Cutting of Bevel and Hypoid Gears
High-speed machining using carbide has been used for some decades for milling and turning operations. The intermittent character of the gear cutting process has delayed the use of carbide tools in gear manufacturing. Carbide was found at first to be too brittle for interrupted cutting actions. In the meantime, however, a number of different carbide grades were developed. The first successful studies in carbide hobbing of cylindrical gears were completed during the mid-80s, but still did not lead to a breakthrough in the use of carbide cutting tools for gear production. Since the carbide was quite expensive and the tool life was too short, a TiN-coated, high-speed steel hob was more economical than an uncoated carbide hob.
This article appeared in the May/June 1998 issue.
