Exsys Tool to Showcase Lehmann Rotary Table and More at MMTS 2016
Exsys Tool Inc. will demonstrate two productivity-enhancing innovations, as well as showcase its industry-leading Preci-Flex tooling system at this year's Montreal Manufacturing Technology Show. A pL Lehmann ultra-high precision 5-axis rotary table and the new Eppinger Compacto tooling base holder will both take center stage in booth 558 at the Place Bonaventure in Montreal, Canada, May 16-18.
To simulate real-world application, Exsys will display the pL Lehmann rotary table's 5th axis cantilever setup and rotary face plate under power. Attendees will experience the system's full 4th axis with Face Plate and 5th-axis functionality as well as its movement within a machine tool work envelope. The 5th-axis table operates in simultaneous machining or productivity-enhancing 3+2 positioning modes.
All pL Lehmann tables consume a minimum of space in the machine work envelope, facilitating optimal tool access to the workpiece. Despite their spacesaving dimensions, the tables and spindles offer strong resistance to pull-out torque and axial force while providing high levels of clamping torque. Lightweight and engineered for low power consumption, the tables feature IP67 rated enclosures. The line also offers the industry's most extensive selection of work holding interface options on the market today.
Both single-spindle and multi-spindle pL Lehmann tables are available in 4th-axis and 4th/5th-axis versions. Swiveling-bridge-style 4-axis tables employ the Roto-Fix clamping yoke for machining of multiple parts. The tables' backlash-free preloaded gear drives (PGD) provide both high torque and high rotation speeds, with spindles capable of 47-111 rpm and cycle times for 90 degrees of 0.34 sec.
The Swiss-manufactured pL Lehmann rotary tables allow users to upgrade a vertical machining center's productivity without incurring the expense of a new machine. The tables are available in four basic models that can be assembled into as many as 240 different configurations. More than 20 different available clamping methods and behind-the-spindle accessories further extend the system's adaptability.
As one of the latest additions to the Eppinger line, the Exsys Compacto base holder delivers speed and accuracy to significantly reduce setup and tool change times for most CNC turning centers. It is available in C3, C4, C5 and C6 sizes and is suitable for all standard PSC adapters and features what provider Exsys deems to be the industry's shortest PSC interface.
