Technical Bevel Gears Helical Gears Hypoid Gears Spiral Bevel Gears Worm Gears
Gears for Nonparallel Shafts
Transmission of power between nonparallel shafts is inherently more difficult than transmission between parallel shafts, but is justified when it saves space and results in more compact, more balanced designs. Where axial space is limited compared to radial space, angular drives are preferred despite their higher initial cost. For this reason, angular gear motors and worm gear drives are used extensively in preference to parallel shaft drives, particularly where couplings, brakes, and adjustable mountings add to the axial space problem of parallel shaft speed reducers.
This article appeared in the September/October 1986 issue.
