Gleason Genesis 200GX Threaded Wheel Grinding Machine to be Introduced at Gear Expo
Gleason recently announced it will introduce advanced machines, tooling, and global customer support services covering a wide array of processes for the complete production and inspection of all types of bevel and cylindrical gears at Gear Expo 2015. On display at booth #1017 will be:
The Genesis 200GX Threaded Wheel Grinding Machine
The 200GX's two spindle concept is designed to combine maximum productivity with minimized idle and set up times. The 200GX is meant to set up from one workpiece to another in just 20 minutes using only one tool. Fully automatic workflow after setup until grinding the first workpieces and the ability to interface with Gleason GMS machines via QR codes increase productivity. Easily accessible machine components make maintenance simple and efficient while standard dimension grinding wheels and dressing tools allow the use of existing tools. The 200GX is designed to be an energy efficient small footprint machine.
The Gleason 300GMSP Analytical Gear Inspection System
A patent-pending base design includes an active leveling system to attenuate a broad spectrum of normal production environment vibrations, yielding measurement values in parallel with those achieved in controlled calibration laboratories, but without the delay of having to move to the lab location. Thermal fluctuations normally associated with shop floor environments are proactively compensated for as well. The system identifies and applies a compensation for factory floor influences in real time.
The 300GMSP Analytical Gear Inspection System is designed and tested to perform as a turn-key gear inspection system in the manufacturing environment, and is designed for applications in aerospace, automotive, and smaller power transmission industries.
