Hypoloid Gear with Small Shaft Angles and Zero-to-Large Offsets
Beveloid gears are used to accommodate a small shaft angle. The manufacturing technology used for beveloid gearing
is a special setup of cylindrical gear cutting and grinding machines. A new development, the so-called Hypoloid
gearing, addresses the desire of gear manufacturers for more freedoms. Hypoloid gear sets can realize shaft angles between zero and 20° and at the same time, allow a second shaft angle (or an offset) in space that provides the freedom to connect two points in space.
