Michael E. Burnett
Manufacturing Processes Broaching Materials Gear Blanks Technical
Improved Broaching Steel Technology
Broaching is a machining technique commonly used to cut gear teeth or cam profiles for the high volume manufacture of power transmission parts used in vehicles (Refs. 1–2). This article shows how the right gear blank material can make all the difference if you want to get more parts out of each tool.
This article appeared in the July 2016 issue.
