KISSsysWeb Allows Companies Simple Calculation of KISSsys Models
KISSsoft recently introduced the KISSsysWeb, a new product that allows companies the calculation of KISSsys models in an easy and simple way using the Internet. This application is designed for sales people who want to recalculate quickly already existing gearboxes with different operating values.
The KISSsys models are selected from the tree structure and the corresponding loads are defined. Not only the speed and torque parameters, but also load spectra as well as radial and axial loads can be specified.
With a single click, the gearbox is calculated and a report is created with service life, safeties, efficiency and other results. This report can then be further used in PDF format.
The models are located on the web server of the company’s network and the application is password-protected - so that all data is secure.
