LMC Face Drivers Improve Turning Productivity
Gear hobbing is easier and more productive with Neidlein's FDNC face driver from LMC Workholding. With Neidlein's FDNC Face Drivers, hobbing can be done in one operation eliminating the use of a chuck. These face drivers also deliver high-tolerance concentricity/runout specifications of .00003" to .00007". Also, the center pin and drive disk system can be adjusted to achieve zero runout.
Using a Neidlein FDNC Face Driver allows the entire workpiece to be exposed for machining and turned in one operation, which eliminates a step in the production process and reduces cycle time. Also efficiency and accuracy are improved since hobs stay on one machine and tolerance stack-ups are eliminated. What's more, the single-axis reference point established by the face driver's center point allows for a higher concentricity. Neidlein gear hob face drivers are available in flange mount and two shank styles: Morse-taper and straight shank. Specials are available that are produced to customer specifications and needs.
FDNC Face Drivers also offer a quick-change drive disk for faster job changeovers, optional coolant flush, and spring-loaded or fixed-center pin. Drive disks are available in clockwise, counterclockwise and bi-directional drive disks. Neidlein makes a complete line of face drivers that use quick-change center points and drive pins for increased productivity and cost efficiency. An online video at its Internet Website is available to see face drivers in action.
LMC Workholding engineers and manufactures high quality chucks and standard and special workholding equipment, including international style power chucks and cylinders, wheel chucks, high volume machining power chucks, Neidlein face drivers and centers, Atling hydraulic steady rests, Richter manual steady rests, Stiefelmayer specialty clamping tools, Chandox brand chucks and cylinders and T de G large chucks.
