Dr.-Ing. Hartmuth Müller
Design Contact Pattern Load Load Carrying Capacity Technical Bevel Gears Hypoid Gears
Local 3-D Flank Form Optimizations for Bevel Gears
Optimizing the running behavior of bevel and hypoid gears means improving both noise behavior and load carrying capacity. Since load deflections change the relative position of pinion and ring gear, the position of the contact pattern will depend on the torque. Different contact positions require local 3-D flank form optimizations for improving a gear set.
This article appeared in the September/October 2003 issue.
