Design Accuracy The Gear Industry Trade Shows & Events MPT Expo Product News Industry News
Mitutoyo CMM Brings Accuracy and Performance to In-line Applications
Mitutoyo America Corporation announces availability of the new MACH-3A CNC Coordinate Measuring Machine - a CMM that brings levels accuracy and performance expected from Mitutoyo to in-line applications. Instead of the basic GO/NO GO judgments common to in-line gaging, the MACH-3A CNC provides comprehensive measurements to enable statistical control utilizing numeric data. The MACH-3A is a clean slate design embodying numerous features dedicated to functionality and high-performance for in-line applications.
The Mitutoyo MACH-3A CMM is a horizontal-arm type machine with high speed and high acceleration (max. speed of 1,212mm/s, max. acceleration of 11,882mm/s2 - both in vector direction) that contributes to high throughput for greater productivity and lower total owning and operating costs.
The MACH-3A is compact, requiring only a minimal envelope which minimizes its impact on line layouts. This, plus high-environmental resistance, make the MACH-3A easy to integrate into both upstream and downstream processes - even under demanding production floor conditions.
Conventional CMMs typically require dust-controlled environments to maintain accuracy. But with a drive unit protected by covers, precision linear guide systems for each axis instead of air bearings, and with its controller and PC installed in a dust-proof housing, the Mitutoyo MACH-3A is highly-resistant to the effects of dust, mist and humidity. Additionally the MACH-3A tolerates a wide range of operating temperatures - guaranteed to maintain accuracy between 5° and 40°C. Additional production-oriented features include a machine status indicator (signaling machine fault or abnormal measurement), an ergonomically-positioned touch-panel monitor with built-in compact keyboard, plus a built-in, industrial-grade controller and PC. It all means the MACH-3A CMM offers the functionality, durability and stability required for 24/7 in-line operation.
The MACH-3A CMM comes with standard with MCOSMOS (Mitutoyo Controlled Open System for Modular Operation Support) which supports virtually every CAD format while providing routines for in-line measurement, data feedback, and process management. MACH-3A architecture together with available Mitutoyo software packages make it easy to integrate this machine with high-level network environments for true enterprise-wide functionality.
