The user is cautioned that when the formulae are used for large average mean spiral angles (βm1 + βm2)/2 > 45°, for effective pressure angles αe > 30° and/or for large facewidths b > 13 mmn, the calculated results of this document should be confirmed by experience.
ISO 10300-2:2023, Calculation of load capacity of bevel gears — Part 2: Calculation of surface durability (macropitting)
Pages: 42
Price: $155.00
SCOPE
This document specifies the basic formulae for use in the determination of the surface load capacity of straight and helical (skew), Zerol and spiral bevel gears including hypoid gears, and comprises all the influences on surface durability for which quantitative assessments can be made. This document is applicable to oil lubricated bevel gears, as long as sufficient lubricant is present in the mesh at all times.
The formulae in this document are based on virtual cylindrical gears and restricted to bevel gears whose virtual cylindrical gears have transverse contact ratios of εvα
The formulae in this document are not directly applicable to the assessment of other types of gear tooth surface damage, such as plastic yielding, scratching, scuffing or any other type not specified.
NOTE: This document is not applicable to bevel gears which have an inadequate contact pattern under load.
ISO 10300-3:2023, Calculation of load capacity of bevel gears — Part 3: Calculation of tooth root strength
Pages: 50
Price: $190.00
SCOPE
This document specifies the fundamental formulae for use in the tooth root stress calculation of straight and helical (skew), Zerol and spiral bevel gears including hypoid gears, with a minimum rim thickness under the root of 3.5 mmn. All load influences on tooth root stress are included, insofar as they are the result of load transmitted by the gearing and able to be evaluated quantitatively. Stresses, such as those caused by the shrink fitting of gear rims, which are superposed on stresses due to tooth loading, are intended to be considered in the calculation of the tooth root stress, σF, or the permissible tooth root stress σFP. This document is not applicable in the assessment of tooth flank fracture.
This document does not apply to stress levels above those permitted for 103 cycles, as stresses in that range can exceed the elastic limit of the gear tooth.
