Seco Introduces X4 for Small Components
Seco has announced the introduction of X4, a new multiedged, tangential tool for grooving and parting off of small components. Available in cutting widths from 0.031” – 0.093”, X4’s inserts minimize material consumption in parting off and enable precise grooving and copying of small and medium-sized complex parts. Performance is further enhanced through X4’s tangential insert bodies that ensure high rigidity, stability and productivity.
To increase flexibility, each X4 insert type can be fastened to any X4 insert seat, allowing for reduction of tooling inventory. Depending on the cutting edge width, the tool’s maximum cutting depth ranges from 0.102” – 0.256” and can cut off maximum bar diameters from 0.205” – 0.512”. X4 inserts are available in neutral, right-hand angled and left-hand angled cutting edge options.
Suitable for a wide variety of common workpiece materials, X4 uses CP500 and CP600 insert grades. CP600 features a mix of toughness and wear resistance suitable for most general applications, while CP500 provides increased wear resistance for more challenging cutting scenarios.
To further increase X4’s performance, inserts with the MC chipbreaking geometry can be applied. This versatile geometry achieves suitable formation of comma and clockspring chips in a variety of materials and uses a straight front edge line to guarantee a straight bottom within a groove.
All X4 toolholders incorporate Seco’s unique Jetstream Tooling Duo technology to further enhance productivity, lengthen tool life and improve chip control. By delivering coolant from two outlets to optimum points in the cutting and heat zones, Jetstream Tooling Duo contributes to efficient cooling, suitable chip formation and high part quality. The X4 is offered in shank sizes of 0.63”, 0.75” and 1.00”, as well as Seco-Capto C4, C5 and C6.
