Heat Treating Carbonitriding Carburizing Nitriding Materials Cast Iron Metallurgy Technical
Selection of Material and Compatible Heat Treatments for Gearing
The manufacturing process to produce a gear essentially consist of: material selection, blank preshaping, tooth shaping, heat treatment, and final shaping. Only by carefully integrating of the various operations into a complete manufacturing system can an optimum gear be obtained. The final application of the gear will determine what strength characteristics will be required which subsequently determine the material and heat treatments.
This article appeared in the May/June 1986 issue.
