Stainless Steel Bevel Gears from QTC Are Stocked in 24 Sizes in Modules 1.5~3
Precision 20-degree pressure angle stainless steel bevel gears from Quality Transmission Components are stocked in 24 sizes in modules 1.5~3. These gears, identified as the SUB Series, are made of SUS303 and conform to precision grade JIS B 1704 grade 3 standards. They are stocked in sizes ranging from Module1.5 to Module 3. Number of teeth range from 15 to 45. Bore sizes range from 8 mm to 20 mm and hub diameters from 25 mm to 80 mm. In addition to these stainless steel bevel gears QTC stocks a wide variety of bevel gears in other materials including: plastic, injection molded, sintered metal, steel, and in specialized types including: Bevel gears and pinion shafts, finished bore, and spiral bevel gear types.
