Robert Errichello
Design Fatigue Technical
The Fatigue Endurance Limit: A Myth
Robert Errichello
The well-known fatigue endurance limit is a convenient myth. That’s the thesis presented by Claude Bathias and Paul C. Paris in their Gigacycle Fatigue in Mechanical Practice.
Whether a real fatigue endurance limit exists continues to be a controversy. The no-limit side is represented in industry standards such as AGMA 2001, which gives an S-N curve that continually slopes downward after 107 cycles. However, other standards, such as ISO 6336, maintain the existence of an endurance limit.
Supporting the no-limit side, Bathias and Paris present important experimental data, including many examples that prove fatigue failures may not occur till well beyond 107 cycles and even after 1010 cycles.
Bathias, who holds a doctorate in mechanical engineering, is director of the Institut des Technologies et des Matériaux Avancés, Conservatoire National des Arts et Metiers, in Paris, France, and is a Fellow of the American Society of Materials.
This article appeared in the November/December 2005 issue.
His co-author, Paris, is senior professor of mechanics at Washington University in St. Louis, MO. Known for his contributions to fracture mechanics, Paris has received awards from the American Institute of Aeronautics and Astronautics and the American Society for Testing and Materials.
Besides examples, the authors also provide excellent guidance on the intricate details of ultrasonic fatigue testing. In addition, their many useful facts on fatigue phenomena include:
• For a large number of alloys, fatigue crack initiation may occur beyond 107 cycles, and the fatigue strength may decrease by 50-200 MPa between 106 and 109 cycles.
• When fatigue occurs beyond 107 cycles in steels, the origin of the fracture is usually not at the surface but in the interior of the specimen.
• Low cycle fatigue cracks are the result of local plastic flow around surface discontinuities, whereas gigacycle fatigue cracks initiate from the interior at inclusions or microstructural defects.
• When fatigue failure occurs at 104 cycles, there are multiple crack origins at the surface; at 106 cycles, there is a single origin at the surface; and at 109 cycles, cracks initiate in the interior of the specimen.
• Equations are given that quantify the effect of nonmetallic inclusions on fatigue strength.
• Corrections are given to account for the different stress states in rotating-bending and tension-compression fatigue tests. After the correction, fatigue data give the same S-N curves regardless of the different loading methods.
• Low temperature causes a shift of the fatigue crack growth curves to higher stress intensity. This is explained by increased tensile properties.
• Gigacycle fatigue tests show the fatigue crack growth threshold ΔKth determined by conventional fatigue testing is reliable for engineering design.
• Equations are given for correcting the fatigue crack growth threshold ΔKth for the effects of the stress ratio R = σminmax.
• A table of threshold stress intensity factors, ΔKth, obtained by ultrasonic fatigue tests, is given for many materials.
• Many useful data are given for fretting fatigue that show fretting can reduce fatigue strength by a factor of three.
Gigacycle Fatigue provides a good overview of recent findings from ultrasonic fatigue testing and discusses many parameters that must be considered when designing machine components for long fatigue life. Given all the above, this book would be an excellent addition to a gear engineer’s library.
To order a copy in North or South America:*
KDC Warehouse
7625 Empire Drive
Florence, KY 41042-2919
Phone: (800) 634-7064
Fax: (800) 248-4724
Internet: www.dekker.com
*As of Oct. 12, 2005, there were no copies in stock. Interested readers may be able to buy copies from other sources via the Internet, such as www.amazon.com.
Robert Errichello is a gear consultant and founder of GEARTECH, a consultancy specializing in gear failure analysis. He’s also a technical editor for Gear Technology and has more than 45 years of experience in the gear industry.
