Crowning
PRODUCT NEWS | 2022-12-07
Dimensional Control Systems (DCS) Examines E-Powertrain Electric Motor Geartrain Simulated Testing with the Digital Twin
The performance of an Electric Vehicle Power Unit is directly connected with critical tolerances. Tolerances drive opportunities for performance enhancement with cost reduction. The tests normally used to determine and validate tolerances are both expensive and time consuming with prototype parts. By replacing the initial tests with Digital Twin simulations, results can be obtained quickly, and at a much lower cost. This article discusses one of these tests and the results.
INDUSTRY NEWS | 2021-12-14
Modified Crowning with Klingelnberg
Klingelnberg examines how engine management in electrically driven cars requires a very different specification of the driveline and the gearbox.
GEAR TALK WITH CHUCK | 2020-11-04
Facing Down Contact Ratio
Before we move on from helix angle restrictions, I want to say a few things about face contact ratio. Soon after the appearance of the first helica...
INDUSTRY NEWS | 2018-11-15
Beautiful on the Inside
Higher Quality Internal Gears
GEAR TALK WITH CHUCK | 2018-09-27
Acceptable Fixes
You do not always have to say “no” when confronted with non-conforming parts. Here are a few “fixes” I have been comfortable authorizing:
GEAR TALK WITH CHUCK | 2018-06-28
Suns and Planets
The first planetary drive I helped take apart had three stages of through hardened spur gears encased in a simple cast iron tube with plates on both ends. Both input and output shafts rotated on taper roller bearings, but everything else had simple bronze bushings.
GEAR TALK WITH CHUCK | 2018-04-10
What About Face Width?
The second component in that face contact ratio equation is the face width. There are almost as many “rules of thumb” for determining the “proper” ...
GEAR TALK WITH CHUCK | 2018-03-13
Bevel Buzzwords
Does technical lingo confuse you? If so, welcome to the bevel gear sector and its special kind of hell. The same “system” that benefited from stand...
GEAR TALK WITH CHUCK | 2017-11-02
Swag of the Expo Awards
My last blog covered the motivation for the Swag of the Expo award and my inspiration in creating it. Top contenders that did not quite qualify for...
TECHNICAL ARTICLES | 2016-06-01
Worm Gear Efficiency Estimation and Optimization
This paper outlines the comparison of efficiencies for worm gearboxes with a center distance ranging from 28 - 150 mm that have single reduction from 5 to 100:1. Efficiencies are calculated using several standards (AGMA, ISO, DIN, BS) or by methods defined in other bibliographic references. It also deals with the measurement of torque and temperature on a test rig — required for the calibration of an analytical model to predict worm gearbox efficiency and temperature. And finally, there are examples of experimental activity (wear and friction measurements on a blockon- ring tribometer and the measurements of dynamic viscosity) regarding the effort of improving the efficiency for worm gear drivers by adding nanoparticles of fullerene shape to standard PEG lubricant
GEAR TALK WITH CHUCK | 2016-02-18
Something to Look Forward to
With Super Bowl 50 behind us, the sporting public can turn its attention to basketball and hockey while baseball teams start spring training. Those...
FEATURE ARTICLES | 2013-08-01
Leading the Way in Lead Crown Correction and Inspection
FEATURE ARTICLES | 2012-05-01
Gear Software - Without it, Hardware Goes Nowhere
It’s a brave, new hardware-software world out there. Players in the worldwide gear industry who don’t have plenty of both run the risk of becoming irrelevant—sooner than later.
FEATURE ARTICLES | 2012-03-01
The Plastic Gear Pay-Off
Eliminating noise, weight and wear proves valuable in 2012.
TECHNICAL ARTICLES | 2011-06-01
Drive Line Analysis for Tooth Contact Optimization of High-Power Spiral Bevel Gears
TECHNICAL ARTICLES | 2010-08-01
Crowning Techniques in Aerospace Actuation Gearing
One of the most effective methods in solving the edge loading problem due to excess misalignment and deflection in aerospace actuation gearing is to localize tooth-bearing contact by crowning the teeth. Irrespective of the applied load, if the misalignment and/or deflection are large enough to cause the contact area to reduce to zero, the stress becomes large enough to cause failure. The edge loading could cause the teeth to break or pit, but too much crowning may also cause the teeth to pit due to concentrated loading. In this paper, a proposed method to localize the contact bearing area and calculate the contact stress with crowning is presented and demonstrated on some real-life examples in aerospace actuation systems.
TECHNICAL ARTICLES | 2010-07-01
Effects of Profile Corrections on Peak-to-Peak Transmission Error
Profile corrections on gears are a commonly used method to reduce transmission error, contact shock, and scoring risk. There are different types of profile corrections. It is a known fact that the type of profile correction used will have a strong influence on the resulting transmission error. The degree of this influence may be determined by calculating tooth loading during mesh. The current method for this calculation is very complicated and time consuming; however, a new approach has been developed that could reduce the calculation time.
VOICES | 2010-03-01
Crowning: A Cheap Fix for Noise and Misalignment Problems
Fred Young, CEO of Forest City Gear, talks about sophisticated gear manufacturing methods and how they can help solve common gear-related problems.
TECHNICAL ARTICLES | 2001-09-01
What "Ease-Off" shows about Bevel and Hypoid Gears
The configuration of flank corrections on bevel gears is subject to relatively narrow restrictions. As far as the gear set is concerned, the requirement is for the greatest possible contact zone to minimize flank compression. However, sufficient reserves in tooth depth and longitudinal direction for tooth contact displacement should be present. From the machine - and particularly from the tool - point of view, there are restrictions as to the type and magnitude of crowning that can be realized. Crowning is a circular correction. Different kinds of crowning are distinguished by their direction. Length crowning, for example, is a circular (or 2nd order) material removal, starting at a reference point and extending in tooth length or face width.
Face Gears: An Interesting Alternative for Special Applications - Calculation, Production and Use
Crown gearings are not a new type of gear system. On the contrary, they have been in use since very early times for various tasks. Their earliest form is that of the driving sprocket, found in ancient Roman watermills or Dutch windmills. The first principles of gear geometry and simple methods of production (shaper cutting) were developed in the 1940s. In the 1950s, however, crown gears' importance declined. Their tasks were, for example, taken over by bevel gears, which were easier to manufacture and could transmit greater power. Current subject literature accordingly contains very little information on crown gears, directed mainly to pointing out their limitations (Ref. 1).
TECHNICAL ARTICLES | 1995-11-01
Determining Spline Misalignment Capabilities
INDUSTRY NEWS | 1993-07-01
Gear Tip Chamfer and Gear Noise; Surface Measurement of Spiral Bevel Gear Teeth
INDUSTRY NEWS | 1992-03-01
Our Experts Discuss Hobbing Ridges, Crooked Gear Teeth, and Crown Shaving
TECHNICAL ARTICLES | 1988-09-01
Crowned Spur Gears: Optimal Geometry and Generation
TECHNICAL ARTICLES | 1988-05-01
Tooth Root Stresses of Spiral Bevel Gears
TECHNICAL ARTICLES | 1987-07-01
Longitudinal Load Distribution Factor for Straddle- and Overhang-Mounted Spur Gears
FEATURE ARTICLES | 1987-03-01
Crowning: A Cheap Fix for Noise Reduction and Misalignment Problems and Applications
Noisy gear trains have been a common problem for gear designers for a long time. With the demands for smaller gear boxes transmitting more power at higher rpms and incumbent demands for greater efficiency, gear engineers are always searching for new ways to reduce vibration and limit noise without increasing costs.
