Manufacturing Cutting Tools Abrasives Product News Industry News
Weiler Abrasives Adds Color-Coding to Brushes for Stainless Steel
Weiler Abrasives has introduced color-coding on its most popular brushes for stainless steel. The color-coding helps stop cross-contamination in operations working with both carbon and stainless steel by making it easy to identify the correct wire brush.
The color-coding is a visual change to an existing product line —  there will be no change to the performance of the stainless steel offering. Part numbers and pricing will also remain the same. The offering includes:
•Roughneck Max Stringer Bead Wheel
•Wolverine Stringer Bead Wheel
•Standard Twist Wheel with Nut
•Knot Wire Cup Brush
•Knot Wire End Brushes
•Crimped Wire End Brushes
Type 316 stainless steel brushes and degreased brushes are available by special order.
