Why do Customers Want to Reinvent OUR Wheel
Ian Shearing, VP Sales, Mitsubishi Gear Center
Over many years of being in the machine tool business, it has been interesting to observe the way we suppliers are forced to quote and sell machine tools to many large companies. Often, we put ourselves through all manner of contortions to win an order, and then—if we do win it—we have to face the eventual ramifications that exist because of that success. Why is this? The answer is very simple: CUSTOMER-SPECIFIC SPECIFICATIONS.
Many large companies have their own machine tool purchasing specifications, which typically include the following:
- Quoting format
- Forms for build reporting
- Frequency of progress report meetings
- Machine configuration to be employed, i.e. horizontal, vertical, etc.
- Individual components to be used in the machine, including electric, hydraulic, lubrication and pneumatic
- Wiring methods to be used, including wire sizes and color
- Piping methods to be used, including type of piping and pipe threads
- Pipe fittings
- Operators screens (HMI)
- Type of PLC logic
- Ancillary equipment to use, such as chillers, oil mist collectors, dust collectors, chip conveyors, etc.
- Special paint specifications
- Vibration sensors and how many are to be used per spindle
- Extended machine acceptance procedures
- Machine noise acceptance levels
- Machine vibration acceptance levels
- Extended warranty demands
- Delivery penalties
- Extended payment demands
The above list is but a small sample of the specifications which must be adhered to when quoting large companies. Normally, these specifications are supplied as a book, but often they are available only via a website whereby we have to print volumes of paper to produce the complete set of specifications, which include specifications for machines other than the ones you are quoting. These specifications are often written in a language which is foreign to us as a builder and thus, open to varied interpretations.
Once a request for quotation (RFQ) has been received, a supplier is lucky to get as many as 30 days to quote. Normally, it is less. Keep in mind that quoting to these specifications often involves a complete redesign of one’s machine, interfacing with unfamiliar suppliers and—because of the timeframe for quoting—a certain degree of guesswork. The end result is a quotation for machines which has some ingredients of conservatism, guesswork, assumptions and hopes that if the order is won, “it will all work out in the end.” Typically, it is a recipe for disaster.
