Anatomy of a Rebuild
Bringing older gear machines back to life
Machine Tool Builders’ complete rebuild of a circa 1990s Pfauter P400G Form Grinding Machine adds years to its useful, productive life at Gallmar Industries.
Tony Johnson, Director, Sales and Marketing,Machine Tool Builders, Inc.
From the outside, Gallmar Industries, nestled into an Oshkosh, WI, neighborhood, looks like any unassuming, medium-sized gear shop. Then take a plant tour with Gallmar’s VP of Operations Kenan Zolota—and prepare to be amazed. The facility stretches on like the Army’s warehouse at the end of Raiders of the Lost Ark, with everything from gear cutting to heat treat, gear grinding to inspection, all under one roof. Gallmar’s breadth of product line is in evidence too: defense-related transmission gears, 60-in. diameter internal gears for mining equipment, axle components for fire/ rescue trucks five feet in length, right down to a bin of brass ammunition casings that Zolota says are a special order.
“Because lives are at stake!” Zolota exclaims when asked why his company has made the investment to control every process and eliminate outsourcing wherever possible. “Failure is not an option for the types of products we produce, and the vehicles they go into, whether an armored MRAP or rescue truck. We don’t shy away from complex, demanding work; outsourcing adds an element of unacceptable risk. The buck stops here.”
New Life for an Old Grinder
Perhaps most amazing of all at Gallmar is the machine that Zolota says is one of his most important, and productive: a Pfauter P400G CNC Form Grinding Machine built sometime in the 1990s. If you’re skeptical that a roughly 30-year-old grinding machine with outdated CNC could live up to the quality and AGMA 15 accuracy requirements demanded of the hard finishing, high-precision work that Gallmar specializes in, you’d be right. Zolota bought the machine just a few years ago in “like-new” condition from Machine Tool Builders (MTB), specialists in rebuilding, retooling, and recontroling gear machines of all makes and models. “We saved many thousands of dollars by buying this machine, and months on delivery,” recalls Zolota. “The machine came with an extended warranty too, not unlike what you would expect for a new machine. Most importantly, MTB is there for us at the drop of a hat, whether for service, spare parts, or help with parts programming, just as if this was a new machine direct from the OEM.”
The P400G’s journey from obsolete to awesome started on the shop floors of MTB, where founder Ken Flowers and his team of technicians view each rebuild as an opportunity that’s akin to restoring a classic Corvette. “If the framework, the ‘iron’ is sound then the restoration can proceed in similar fashion,” Flowers explains. “Nothing is left untouched, every active component, including CNC, is upgraded, every mechanical piece meticulously inspected then repaired or replaced.”
