Donner + Pfister AG in Switzerland offers their portable profile and lead inspection measuring unit for heavy and large gears, where no measuring machine is available. Detailed technical specifications include: Module 3-80 mm; Base diameter 600 mm with no maximum limitation; Helix angle: +/- 35°; Maximum face width: 1300 mm; Accuracy: VDI 2612 Group I.
"Gear Train" is a new Gear Technology section focusing on training and education in the gear industry. For the first installment, we've focused on AGMA's online and video training programs.
If a gear system is run continuously for long periods of time—or if the starting loads are very low and within the normal operating spectrum—the effect of the start-up conditions may often be insignificant in the determination of the life of the gear system. Conversely, if the starting load is significantly higher than any of the normal operating conditions,
and the gear system is started and stopped frequently, the start-up load may, depending on its magnitude and frequency, actually be the overriding, limiting design condition.
Photography is an essential part of gear failure analysis. It not only provides a fast, convenient way to accurately document the appearance of gear failure, but also is an effective diagnostic tool because the magnification obtained through photographic enlargement and slide projection often discloses evidence that may have been missed if the gears were not photographed.
In the lubrication and cooling of gear teeth a variety of oil jet lubrication schemes is sometimes used. A method commonly used is a low pressure, low velocity oil jet directed at the ingoing mesh of the gears, as was analyzed in Reference 1. Sometimes an oil jet is directed at the outgoing mesh at low pressures. It was shown in Reference 2 that the out-of-mesh lubrication method provides a minimal impingement depth and low cooling of the gears because of the short fling-off time and fling-off angle.(3) In References 4 and 5 it was shown that a radially directed oil jet near the out-of-mesh position with the right oil pressure was the method that provided the best impingement depth.
