The Motion + Power Technology Expo is a three-day show that’s designed for the gear and power transmission industry, representing the entire community of professionals involved in the life of a gear, gearbox or other power transmission device—from design to manufacturing, testing, heat treating and more. You can find the suppliers of the equipment to make gears as well as gear and gear drive manufacturers themselves, along with related suppliers of things like software, tooling, lubrication, bearings and more.
With global wind turbine demand set to quadruple by the end of the decade, manufacturers are seeking new technologies to ramp up production of gears that can operate in any environment, around the clock, for years to come.
2023 is shaping up to be our planet’s hottest year on record, and the wind energy industry is feeling the heat. The GWEC (Global Wind Energy Council) says that the rate of wind turbine installations will need to quadruple globally by the end of the decade if we’re to achieve the IRENA’s (International Renewable Energy Agency) goal of net zero carbon emissions by 2050—and keep the average annual temperature worldwide from increasing more than the predicted 1.5° C. Fortunately, “net zero” commitments are gathering global momentum. Before year’s end, total global windpower is expected to reach a historic milestone of 1 TW of installed capacity, eliminating 1.2 billion tons of CO2 annually, roughly the equivalent of all the carbon emissions of South America.
This article describes a cloud-based process and machine component monitoring system called ARGUS. The term “swarm” is used for a large population of gear-grinding machines of individual and independent customers connected to the ARGUS system and the ARGUS cloud. These “swarm” machines permanently feed their anonymized process data into a common cloud database. Reishauer uses this database for big data analytics to discover patterns that indicate successful process and machine component behavior patterns worth integrating into the ARGUS algorithms and propagate them across the complete ARGUS customer base.
Automate 2023 in Detroit featured 757+ exhibits with 30,000+ registrants. The success of the 2022 and 2023 events prompted A3 to continue the show as an annual event moving forward. Historically, the show was biennial until the pandemic changed scheduling.
For the transmissions of electric vehicles to develop the desired high torque under all driving conditions, a very large gear ratio is needed, which requires high speeds. And to ensure sufficient momentum at all speeds and enable the driver to accelerate without shifting gears, the electric drive must achieve up to 15,000 rpm, which is about three times that of a typical combustion engine. This puts a lot of strain on the rotor shaft. The manufacturers of rotor shafts are thus facing new challenges, such as the significantly lower shape and position tolerances and the need for greater machining precision.
Range anxiety, infrastructure debates, raw material shortages and unanswered questions shake up automotive’s move toward electrification—the journey won’t be easy, but the industry will push technology until it finds a way.
If trade shows are still a major indicator of market growth, the construction and off-highway industries seem to be in a good place in 2023. CONEXPO-CONAGG and IFPE 2023 welcomed more than 139,000 attendees to Las Vegas in March. These visitors were treated to 2,400 exhibitors from 36 countries reaffirming the belief that innovation and sustainability will drive these markets in the coming years.
On the surface, it may not seem like the gear inspection industry has changed much over the last few years. Shops still primarily use either machines that are dedicated solely to measuring gears, or multiuse Coordinate Measuring Machines (CMMs). And regardless of which machine they use, software serves as the backbone that supports their many diverse sensors.
During our interactions with customers, we find the common challenge faced by customers about getting incorrect component parameters using corrected lead hobs. To address the challenge, we will talk about what corrected lead hobs are, why it is necessary to design such hobs, and how to set up the hob on the machine depending upon the type of hobbing machine (manual, semiautomatic CNC, or CNC).
Gleason LeCount Adjustable Expanding Mandrels offer a fast, flexible and amazingly simple solution for metrology applications where speed, accuracy and repeatability are paramount
Keep it simple. More often than not it turns out to be the best course of action in life and on factory floors. Take, for example, Gleason LeCount Expanding Mandrels. You’ll find them in quality labs around the world, delivering reliable, repeatable workholding performance for the inspection of gears and other bore-type workpieces. Quality labs today are at the epicenter of the drive to produce increasingly complex, high-precision parts, while at the same time racing to take time and cost out of the inspection process. Counter-intuitively, perhaps, the best workholding solution to meet these ambitious new inspection requirements turns out not to be something new and more complex—but the simplest solution of all: Gleason LeCount Expanding Mandrels.
