Design Scuffing The Gear Industry AGMA Technical
Calculated Scuffing Risk: Correlating AGMA 925-A03, AGMA 6011-J14 and Original MAAG Gear Predictions
This paper relates specifically to gears that are finish ground and considered high speed per ANSI/AGMA 6011; meshing elements with PLVs (pitch line velocities) in excess of 35 m/s or rotational speeds greater than 4,500 rpm.
This article appeared in the March/April 2020 issue.
