Manufacturing Cutting Tools Abrasives CBN Processes Grinding Honing Technical Ground Gears
Hard Gear Finishing With CBN-Basic Considerations
For over 50 years, grinding has been an accepted method of choice for improving the quality of gears and other parts by correcting heat treat distortions. Gears with quality levels better than AGMA 10-11 or DIN 6-7 are hard finished, usually by grinding. Other applications for grinding include, but are not limited to, internal/external and spur/helical gear and spline forms, radius forms, threads and serrations, compressor rotors, gerotors, ball screw tracks, worms, linear ball tracks, rotary pistons, vane pump rotators, vane slots, and pump spindles.
This article appeared in the May/June 1998 issue.
