Design Load Scoring Scuffing The Gear Industry Standards ISO 6336 Technical
Influence of Geometrical Parameters on the Gear Scuffing Criterion - Part 2
In ParI 1 several scuffing (scoring) criteria were shown ultimately to converge into one criterion, the original flash temperature criterion according to Blok. In Part 2 it will be shown that all geometric influences may be concentrated in one factor dependent on only four independent parameters, of which the gear ratio, the number of teeth of the pinion, and the addendum modification coefficient of the pinion are significant.
This article appeared in the May/June 1987 issue.
