Design Optimization Software Stress Materials Plastic Technical Helical Gears
Practical Optimization of Helical Gears Using Computer Software
The aim of this article is to show a practical procedure for designing optimum helical gears. The optimization procedure is adapted to technical limitations, and it is focused on real-world cases. To emphasize the applicability of the procedure presented here, the most common optimization techniques are described. Afterwards, a description of some of the functions to be optimized is given, limiting parameters and restrictions are defined, and, finally, a graphic method is described.
This article appeared in the May/June 1993 issue.
