Cutting Tools Tool Coating Tool Life Aerospace Automotive Product News
Star SU Offers New Louis Bélet Drill Line Dedicated to Stainless Steel
Star SU, Star Cutter Company’s marketing, sales and service affiliate, announces the availability of a new line of expert internal coolant drills from Louis Bélet, designed specifically for stainless steels. This drill line is suited for application in all fields where stainless steel is used, such as watchmaking, medical, aerospace, automotive, etc.
Machining of stainless grades, such as martensitic and austenitic, is often slow and prone to errors.  To address these challenges, one of the drills in the new range (REF .376-10) achieves depths of up to 10xd and at rates that are 3x – 4x faster than previous drills. It also eliminates the need for pecking, resulting in smoother, more productive operations. Further, to eliminate the need for a centering or deburring device, a second drill (REF .336H) can be used, with or without a chamfer, to produce a pilot hole.
These drills are designed with a compression chamber that minimizes coolant pressure loss, improving efficiency and accuracy with the drills able to hold concentricity of <0.003mm at the drill tip.  Additionally, an increased surface area of the lube holes and their specific shape enable these drills to achieve 3x the throughput compared to previous generations.
To tackle complex stainless steels and even superalloys like CoCr (Phynox), Louis Bélet developed a micro-grain carbide specifically for stainless steel applications. The TISI (titanium-silicon) coating reduces friction, decreases heat buildup, and prevents burr formation, ensuring longer tool life. The unique cutting-edge preparation also ensures optimal coating adhesion and durability for longer tool life.
Star SU is the exclusive representative of Louis Bélet SA (Switzerland) precision cutting tools in North America.
star-su.com/partners-brands/louis-belet/
This article appeared in the March/April 2025 issue.
