Dr. Hermann J. Stadtfeld
Design Profile Profile Shift Technical Bevel Gears
The Importance of Profile Shift, Root Angle Correction and Cutter Head Tilt
Chapter 2, Continued In the previous sections, development of conjugate, face milled as well as face hobbed bevel gearsets - including the application of profile and length crowning - was demonstrated. It was mentioned during that demonstration that in order to optimize the common surface area, where pinion and gear flanks have meshing contact (common flank working area), a profile shift must be introduced. This concluding section of chapter 2 explains the principle of profile shift; i.e. - how it is applied to bevel and hypoid gears and then expands on profile side shift, and the frequently used root angle correction which - from its gear theoretical understanding - is a variable profile shift that changes the shift factor along the face width. The end of this section elaborates on five different possibilities to tilt the face cutter head relative to the generating gear, in order to achieve interesting effects on the bevel gear flank form. This installment concludes chapter 2 of the Bevel Gear Technology book that lays the foundation of the following chapters, some of which also will be covered in this series.
This article appeared in the January/February 2016 issue.
