Dr.-Ing. Karsten Stahl
Dr.-Ing. Thomas Tobie
Daniel Fuchs
Gear Rating Load Carrying Capacity Tooth Bending Tooth Root Shot Peening Gear Steels
Tooth Root Bending Strength of Shot-Peened Gears Made of High-Purity Steels up to the VHCF Range
Standardized methods, like AGMA 2001-D04 or ISO 6336 for the calculation of the load carrying capacities of gears are intentionally conservative to ensure broad applicability in industrial practice. However, new applications and higher requirements often demand more detailed design calculations nowadays; for example: long operating lives in wind power gearboxes or fewer gear stages and higher speeds in e-mobility applications result in higher load cycles per tooth in a gearbox.
This article appeared in the March/April 2022 issue.
