Two Newly Revised AGMA Standards
Double flank tester.
AGMA is pleased to announce the publication of two new revisions: ANSI/AGMA 2116-B24, Evaluation of Double Flank Testers for Radial Composite Measurement of Gears, written by the AGMA Gear Accuracy Committee, and ANSI/AGMA 6008-B24, Specifications for Powder Metallurgy Gears written by the AGMA Powder Metallurgy Committee.
ANSI/AGMA 2116-B24
ANSI/AGMA 2116-B24 provides the evaluation criteria for double flank testers. It also recommends artifact sizes and geometry along with measurement system conditions. In Annex A of the standard a method for estimating calibration uncertainty is provided.
Between 1994 and 1998 the AGMA Calibration Committee published three standards on calibration of gear measuring instruments. The AGMA documents were used as the basis to create ISO 18653:2003 Gears – Evaluation of instruments for measurement of gears, and ISO/TR 10064-5:2005, Cylindrical gears – Code of inspection practice – Part 5: Recommendations relative to evaluation of gear measuring instruments. AGMA adopted the ISO standards, however the ISO standards did not cover evaluation methods of double flank testers. So the first edition of ANSI/AGMA 2116 was created in 2005 to fill in that gap.
This 2024 edition of ANSI/AGMA 2116 has incorporated information from an AGMA information sheet (AGMA 935-A05) into a new Annex A, titled Recommendations relative to the evaluation of radial composite gear double flank testers. Information from the former Annex B, Calibration certificate requirements, has been moved into the body of the document. Other changes are general updates to the latest practices.
ANSI/AGMA 6008-B24
ANSI/AGMA 6008-B24 provides comprehensive details for the design, processing, and specifications of powder metallurgy, PM, steel gears that need to be agreed upon between the PM gear supplier and the purchaser. These include: definition of terms, gear tooth geometry considerations, inspection, PM gear materials, drawing specifications, heat treatment, and mechanical testing.
