Design Accuracy Bearings Relief Heat Treating Hardness Technical Bevel Gears Double Helical Gears Helical Gears Spiral Bevel Gears
Zerol Bevel Gears: Tribology Aspects in Angular Transmission Systems, Part III
Zerol bevel gears are the special case of spiral bevel gears with a spiral angle of 0°. They are manufactured in a single-indexing face milling process with large cutter diameters, an extra deep tooth profile and tapered tooth depth.
This article appeared in the November/December 2010 issue.
