A Split Happened on the Way to Reliable, Higher-Volume Gear Grinding
Dr.Hermann J.Stadtfeld
In the past 15-20 years, gear grinding has evolved into a stable, much-used process in industrial production,especially for making high-quality automotive transmission gears.
During this evolution, though, a split occurred between U.S. and European bevel gear manufacturers. Today, they live in one of two camps: the face-hobbing/lapping camp and the face-milling/grinding camp.
In the mid- to late-1980s, when gear grinding was introduced for industrial production, gear manufacturers already knew that gears ground to a very high AGMA quality level didn’t have particularly low noise emission levels. The reason was the high spacing and flank form accuracy, which generated tooth meshing impacts during operation. These impacts occurred in angular inter- vals with very little variation.
The precise impact frequency created a so-called pure frequency tone that was emitted as part of the structure and air-borne noise. In the automotive industry, this pure tone noise could be easily distinguished from other sounds, such as noise from the wind, the engine and the tires. Moreover, the pure tone noise felt disturbing.
Gear manufacturers, however, were still attracted to grinding. Its beauty lay in its ability to achieve a low amount of variation in gear flank geometry within a production batch and in its ability to achieve such low amounts from batch to batch regardless of different levels of heat treat distortion resulting from steel variations.
