Design Equations Gear Noise Gear Rating Mathematics Manufacturing Machine Tools CNC Processes Grinding The Gear Industry AGMA Standards Technical Ground Gears
CNC Gear Grinding Methods
Grinding in one form or another has been used for more than 50 years to correct distortions in gears caused by the high temperatures and quenching techniques associated with hardening. Grinding improves the lead, involute and spacing characteristics. This makes the gear capable of carrying the high loads and running at the high pitch line velocities required by today's most demanding applications. Gears that must meet or exceed the accuracy requirements specified by AGMA Quality 10-11 or DIN Class 6-7 must be ground or hard finished after hear treatment.
This article appeared in the May/June 1997 issue.
