Robert Errichello
John B. Amendola
John B. Amendola III
Design Bearings Temperature Tooth Profile Wear Lubrication Friction AGMA Education & Training Technical Gears
Defining the Tooth Flank Temperature in High-Speed Gears
The objective of this paper is to improve the methodology for determining the tooth flank temperature. Two methods are proposed for assessing scuffing risk when applying AGMA 925 for high-speed gears. Both methods provide similar results.
This article appeared in the May 2022 issue.
