The present article contains a preliminary description of studies carried out by the authors with a view toward developing asymmetrical gear teeth. Then a comparison between numerous symmetrical and asymmetrical tooth stress fields under the same modular conditions follows. This leads to the formulation of a rule for similar modules governing variations of stress fields, depending on the pressure angle of the nonactive side. Finally a procedure allowing for calculations for percentage reductions of asymmetrical tooth modules with respect to corresponding symmetrical teeth, maximum ideal stress being equal, is proposed. Then the consequent reductions in size and weight of asymmetrical teeth are assessed.
Most steel gear applications require appreciable loads to be applied that will result in high bending and compressive stresses. For the material (steel) to meet these performance criteria, the gear must be heat treated. Associated with this thermal processing is distortion. To control the distortion and achieve repeatable dimensional tolerances, the gear will be constrained during the quenching cycle of the heat treatment process. This type of fixture quenching is the function of gear quench pressing equipment.
To mechanical engineers, the strength of gear teeth is a question of constant recurrence, and although the problem to be solved is quite elementary in character, probably no other question could be raised upon which such a diversity of opinion exists, and in support of which such an array of rules and authorities might be quoted. In 1879, Mr. John H. Cooper, the author of a well-known work on "Belting," made an examination of the subject and found there were then in existence about forty-eight well-established rules for horsepower and working strength, sanctioned by some twenty-four authorities, and differing from each other in extreme causes of 500%. Since then, a number of new rules have been added, but as no rules have been given which take account of the actual tooth forms in common use, and as no attempt has been made to include in any formula the working stress on the material so that the engineer may see at once upon what assumption a given result is based, I trust I may be pardoned for suggesting that a further investigation is necessary or desirable.
