I make all the double helical gears that go into a gearbox - four
different gears in this unit. If the gear module for the bull gear and the
intermediate gear are the same (these are the two individual gears that
mate), and the gear module for the high-speed pinion and high-speed
gears are the same (these are the other two individual gears that mate
in the gear box as well), is it then possible to just use two hobs in this
setup to make all four gears, since they mate together with each other?
We are currently using a different gear hob for each gear.
While designing gear and spline teeth, the root fillet area and the corresponding maximum tensile stress are primary design considerations for the gear designer. Root fillet tensile stress may be calculated using macro-geometry values such as module,
minor diameter, effective fillet radius, face width, etc.
THE FINAL CHAPTER
Looking for some simple yet useful advice heading into IMTS 2016? Never second guess your machine tool investment. Flexibility is a
mandatory requirement in gear manufacturing today. Accuracy, reliability and efficiency must improve with each new machine tool purchase. Innovation is always the end game. So it comes as no surprise that IMTS 2016 attendees will have plenty of gear grinding technologies
to consider this fall.
