Forty of Gear Technology's pre-show and show issue advertisers will be exhibiting a wide range of goods and services at AGMA's Gear Expo '93. The exhibition will be held October 10-13 at Cobo Conference & Exhibition Center in Detroit, MI. Below is an alphabetical listing of these advertisers and a preview of what can be seen at their booths.
The Hobbing Process
Gear Expo '93 - another trade show, another plea to send people and/or equipment out of town, away from the office or plant. Another bid to spend time, money, and effort. Oh, please! Hasn't anybody heard that these are the "lean and mean" '90s?
AGMA's Gear Expo '93 is expected to be at least 10% larger in terms of floor space than the '91 show, according to Joe Franklin, AGMA's executive director. "As of June 1, we have 80 exhibitors registered", he says.
Gear Expo '93, "The World of Gearing," is scheduled for October 10-13 at Cobo Conference & Exhibition Center, Detroit, MI. Hours are 9 a.m. to 5 p.m. on all four days of the show.
