should be considered.
stress will be discussed.
This paper addresses the lubrication of helical gears - especially
those factors influencing lubricant film thickness and pressure.
Contact between gear teeth is protected by the elastohydrodynamic
lubrication (EHL) mechanism that occurs between nonconforming
contact when pressure is high enough to cause large
increases in lubricant viscosity due to the pressure-viscosity
effect, and changes of component shape due to elastic deflection.
Acting together, these effects lead to oil films that are stiff
enough to separate the contacting surfaces and thus prevent
significant metal-to-metal contact occurring in a well-designed
gear pair.
Broaching is a machining technique commonly used to cut gear teeth or cam profiles for the high volume manufacture of power transmission parts used in vehicles (Refs. 1–2). This article shows how the right gear blank material can make all the difference if you want to get more parts out of each tool.
