QuesTek Innovations LLC is applying its Materials by Design computational design technology to develop a new
class of high-strength, secondary hardening gear steels that are optimized for high-temperature, low-pressure (i.e., vacuum) carburization. The new alloys offer three different levels of case hardness (with the ability to “dial-in” hardness profiles, including exceptionally high case hardness), and their high core strength, toughness and other properties offer the potential to reduce drivetrain weight or increase power density relative to incumbent alloys such as AISI 9310 or Pyrowear Alloy 53.
Custom Gear and Machine, Inc., of Roscoe, IL, recently purchased a Reishauer RZ400 gear grinder and, on one job, has seen the cycle time drop from 40 minutes to six minutes, according to Tim Rose, vice president
of manufacturing, who runs the business with co-owners Dave Patterson and Mike Rasmann.
In this paper, a method is presented for analyzing and documenting the pitting failure of spur and helical gears through digital photography and automatic computerized evaluation of the damaged tooth fl ank surface. The authors have developed an accurate,
cost-effective testing procedure that provides an alternative to vibration analysis or oil debris methods commonly used in conjunction with similar test-rig programs.
