From countless conversations with folks running gear operations, we know you're probably focused on..."
The Swabian transmission and drive solutions manufacturer SPN Schwaben Präzision Fritz Hopf GmbH manufactures gearboxes, gears, and drive systems according to individual customer requirements.
Is your grinding or finishing process optimized for maximum efficiency? The Weiler Process Solutions (WPS) evaluation helps gear manufacturers to enhance productivity, reduce costs, and improve safety. Our expert team will assess your operation and recommend tailored solutions to optimize performance. Sign up for a free evaluation today, and we’ll contact you within 48 hours to discuss how we can help—potentially visiting your site for a hands-on assessment.
Discover how machine learning minimizes roughness variations in profile grinding, enhancing the performance and durability of wind power gearboxes. The latest research by KAPP NILES demonstrates an optimized dressing process that improves surface quality on tooth flanks after profile grinding for next-generation wind turbines.
Gear Profile Grinding Machine ZP 10 with automatic tool changer from Kapp Niles. The machine concept stands for maximum workpiece quality, flexibility and a long service life. The basic machines are equipped with a dresser, integrated measuring device, balancing unit and comprehensive software. The machines feature generously dimensioned rotary tables with electrical direct drive and large rotary table bores.
Join us at AISTech, Booth 1161, where our abrasives experts will help you to unlock your full potential. You will learn about Precision Express, our latest innovative service that combines on-demand profiling with readily available grinding wheels, cutting your lead times from months to just days. For those who value productivity-enhancing solutions and want a competitive edge, Weiler Abrasives is a premier partner.
C&B Machinery supported the reshoring of a 30” double-disc grinding machine for a major U.S. automotive manufacturer’s transmission plant. Originally installed in an overseas facility, this machine is now being brought back to the U.S., where it will be retooled, reautomated, and upgraded to enhance performance and efficiency for a Michigan-based production program.
The two ZFA series gear grinders are designed to perform high-speed and high-precision finish machining on gears. The two models are each designed for a different gear size range, with ZFA160 capable of handling gears with an external diameter of up to 160 mm, and ZFA260 accommodating gears with an external diameter of up to 260 mm. Capable of meeting the increasingly sophisticated users’ needs, both ZFA160 and ZFA260 can mass-produce gears with a gear accuracy level equivalent to ISO 3 (JIS level N3).
With the new Automated Tool Production (ATP) system, Walter now offers a comprehensive automation solution for cutting tools. ATP networks grinding, eroding and measuring machines from Walter, as well as upstream and downstream machines from other system partners in the production process.
Overall developments and widespread public awareness of man-made climate change are transforming the way people think. The awareness has inspired a shift towards a more ecologically sustainable way of life. Driven by policymaking and technological innovation, ambitious efforts are underway to reduce greenhouse gas emissions to curb the rise in average temperatures. A key focus of these efforts is the mobility sector.
Weiler Abrasives has announced its new blending disc product lineup that is ideal for a wide range of blending, weld cleaning and polishing needs. The blending discs can help operations save time and money through faster material removal and longer product life in such applications as shipbuilding, structural fabrication and welding.
The world of bevel gear grinding is a complex topic. How do you determine which grinding and dressing parameters to select for a desired surface finish? What type of grinding wheel should be used? What type of dresser should be used? How do all these factors affect the gear noise and quality levels? These are some questions that will be addressed in this article.
The Curvic coupling from the aviation sector is a critical component used in helicopters. Previously, the external helical gearing was manufactured on one machine and the curvic coupling gearing on a second machine. The external and internal cylindrical grinding was then carried out on a third machine in two consecutive process steps.
From the outside, Gallmar Industries, nestled into an Oshkosh, WI, neighborhood, looks like any unassuming, medium-sized gear shop. Then take a plant tour with Gallmar’s VP of Operations Kenan Zolota—and prepare to be amazed. The facility stretches on like the Army’s warehouse at the end of Raiders of the Lost Ark, with everything from gear cutting to heat treat, gear grinding to inspection, all under one roof. Gallmar’s breadth of product line is in evidence too: defense-related transmission gears, 60-in. diameter internal gears for mining equipment, axle components for fire/ rescue trucks five feet in length, right down to a bin of brass ammunition casings that Zolota says are a special order.
Attendees will gain familiarization with spur, helical, bevel and hypoid gear nomenclature, the use of various cutting methods in Gleason machines as well as the tooling and processes used in gear manufacturing. Topics include gear classification, cutting methods, blank tolerances and configurations, inspection, testing, and workholding.
UK-based PTG Holroyd has announced that, in the future, all models in its TG Series of ultra-precise helical rotor and thread grinding machines will be equipped with the Siemens digitally native Sinumerik One CNC as standard.
UK-based PTG Holroyd has announced that going forward, all models in its TG Series of ultra-precise helical rotor and thread grinding machines will be equipped with the Siemens digitally native Sinumerik One CNC as standard.
Nidec Machine Tool Corporation (“Nidec Machine Tool” or the “Company”), a group company of Nidec Corporation, today announced that it has developed the a high-accuracy polishing (grinding) method to machine internal gears for mass production that are used for automobiles’ drive units and transmissions and robots’ joints. While there are already high-accuracy polish-machining methods for external gears for mass production, no such methods have been available for internal gears. After conducting research focused on this point, the Company has achieved positive results in securing the level of accuracy and production that conventional grinding, honing, or skiving methods could not.
For over 10 years, the mechanical engineering company Kapp Niles has been working intensively on the topic of gears in e-mobility and has established itself as a pioneer in this rapidly growing industry. With a focus on innovation and quality, Kapp Niles offers customized solutions for the production of gearboxes and gears in electric vehicles.
This article introduces the process of polish grinding of gears. Improved surface quality increases the overall efficiency of gearboxes, resulting in reduced friction and torque loss, higher power density, and noise-optimized gears (lower NVH); all these factors are highly relevant, especially for electric drives. When Reishauer developed polish grinding in 2012, the process aimed to improve the efficiency of ICE engine transmissions, and the set goals were easy to achieve. Today, in 2023, the situation is dramatically different. While an ICE engine operates at around 3,000 rpm and supplies acoustic masking of the gear noise, EV drivetrains feature up to 20,000 rpm and offer no such masking.
Founded in 1987 by Clorindo Mattei, Clortech Precision Cutting Tools is a family business with wife Carmela handling bookkeeping, while son Patrick is the vice-president of production and sisters Emilia and Mena are the managing director and quality assurance director respectively. The company is a Montreal manufacturer of custom precision tools that sells to various industries including aerospace, recreational vehicles, rail and automotive. Products include shafts, gauges, broaches, bushings, extra-long reamers, special diameter formed end mills, special contouring tools.
United GrindingAsia Pacific (UGAP) Pte. Ltd. is the new group subsidiary of United Grinding Group (UGG). UGG has had a presence in Southeast Asia for many years thanks to representatives and the Walter Ewag Asia Pacific subsidiary. This new group strengthens the United Grinding's presence in the region with grinding, eroding, laser, and measuring machines.
IPTEX 2024 (Pune, India) is an important event for all relevant stakeholders in automobile, aerospace, or energy as well as manufacturers, buyers, partners, and consultants. Focus industries include mechanical power transmission, electrical power transmission, linear motion drives, fluid power and IoT/smart technology. IPTEX will provide a consistent channel of communication to the members of this industry to come together under one roof and participate in technical seminars, share knowledge and expertise with industry leaders and to be a part of discussion on policy codes, standards and challenges faced by the industry.
EMO Hannover 2023 didn’t simply provide PTG Holroyd with a platform to showcase its industry-leading helical rotor and gear milling and grinding machines to a global audience. The UK-based machine tool manufacturer was presented with Siemens’ Digital Transformer award during the event.
Are you looking for a solution to ensure quality and increase productivity in gear manufacturing? There is a clear trend towards saving resources and sustainable manufacturing. Here Liebherr highlights their gear technology, gear-cutting tools, measuring technology, and automation systems.
Automobile manufacturers can develop ever more sophisticated car body molds because they can rely on 5-axis portal machines as the backbone of automotive tool and die making. The aerospace industry achieves unprecedented part quality thanks to full technology integration of milling, turning and grinding, ensuring maximum passenger safety. Thanks to 5-axis technology in large format, portal machines ensure that hydroelectric power can be converted into energy. Mechanical engineering also benefits worldwide from portal machines from Pfronten, which repeatedly demonstrate their performance in demanding machining operations such as gear production. DMG Mori has more than 1,400 Portal machines installed worldwide.
New software, hardware, and design features significantly improve surface finish, accuracy, and controlled runout, ensuring batch consistency from the first ground tool to the last. The FX7 Ultra is a refined solution for precision grinding in industries that rely on small tools, including electronics, telecommunications, medical devices, aerospace, automotive, die mold, and general machining.
Star Cutter Company has acquired Tru Tech CNC grinding systems from Resonetics (Nashua, N.H.), assuming all design and manufacturing of the Tru Tech high precision CNC grinding machines currently performed at the Michigan facilities in Mt. Clemens and Lewiston. Additionally, Star Cutter secures the service, training, and spare parts support for Tru Techs’ vast installation base across North America and Europe.
At EMO 2023 in Hannover, Germany, the United Grinding booth in hall 11, booth E34 will showcase 16 machines, innovative technology, and updates from the Customer Care team. The United Grinding Group, one of the world's leading manufacturers of grinding, eroding, laser and measuring machines, is considered one of the pioneers in the development of innovative technologies in the manufacturing industry. Fittingly, ”Innovate Manufacturing” is the motto of this year’s EMO in Hannover.
This article describes a cloud-based process and machine component monitoring system called ARGUS. The term “swarm” is used for a large population of gear-grinding machines of individual and independent customers connected to the ARGUS system and the ARGUS cloud. These “swarm” machines permanently feed their anonymized process data into a common cloud database. Reishauer uses this database for big data analytics to discover patterns that indicate successful process and machine component behavior patterns worth integrating into the ARGUS algorithms and propagate them across the complete ARGUS customer base.
2023 is shaping up to be our planet’s hottest year on record, and the wind energy industry is feeling the heat. The GWEC (Global Wind Energy Council) says that the rate of wind turbine installations will need to quadruple globally by the end of the decade if we’re to achieve the IRENA’s (International Renewable Energy Agency) goal of net zero carbon emissions by 2050—and keep the average annual temperature worldwide from increasing more than the predicted 1.5° C. Fortunately, “net zero” commitments are gathering global momentum. Before year’s end, total global windpower is expected to reach a historic milestone of 1 TW of installed capacity, eliminating 1.2 billion tons of CO2 annually, roughly the equivalent of all the carbon emissions of South America.
TCI Precision Metals has announced the expansion of its grinding services to meet the needs of customers wanting more value-added materials processing. Customers who have traditionally sourced materials and shipped them to and from TCI Precision Metals for specific grinding requirements can now eliminate additional in-house processing, shorten materials lead times, and increase production efficiency. TCI can source materials mill-direct, precision cut oversize, then grind or mill two or six sides to close tolerance customer specifications.
C&B Machinery (C&B) announced the completion of their newly redesigned Clamp Bore Face Grinding Machines. After months of planning, redesigning, and building the machines, C&B is excited to announce the latest CBVR-2F-2S model Clamp Bore Grinders.
Bourn & Koch, Inc. of Rockford, IL, is pleased to report that Ross Wegryn-Jones has recently joined the company as our National Sales Manager. Ross will be responsible for the sales of gear manufacturing machines, precision grinding machines, and specialty machine tools for unique manufacturing applications. This includes Bourn & Koch horizontal gear hobbers; Fellows gear shapers; Blanchard rotary surface grinders, and Bourn & Koch’s new MT3 vertical grinding machine.
Manufacturing high-accuracy worm gears and screws alongside precision spur and helical gears has traditionally required the use of two quite different CNC grinding machines. Thanks to PTG Holroyd’s newly launched HG350-WG worm and gear grinding center, however, just one machine can now complete both tasks.
Machine Tool Builders Inc. has introduced a comprehensive new recontrol/retrofit package for larger-capacity profile grinding gear machines with outdated controls that add highly desirable performance at a fraction of the cost for new machinery.
A significant amount of work is being done to advance the technology of gears specifically for use in electric vehicles. No longer hidden by the noise of the internal combustion engine, the transmission has taken center stage as the noisiest component in most electric-driven cars.
When grinding steel parts, the surface of the part can "burn" if too much heat is applied in a short time. Grinding burn refers to all those structural changes in edge zones of steel parts that are caused by grinding processes in steels due to the thermal energy introduced. Grinding burn can mainly occur in the form of tempering zones or new hardening zones.
For the research developed in this work, an existing simulation model of the generating gear grinding process based on a penetration calculation approach is used. Further, an extension of the model considering a realistic modeling of the grinding worm topography and the macro movements of the grinding worm during the process is presented. The result of the simulation is the microinteraction characteristics throughout
the grinding of the gear flank. In the end, the information about microinteraction characteristics obtained will be used for the calculation of force and energy in generating gear grinding.
Fabtech provides a 'one-stop-shop' for metal forming, fabricating, welding, and finishing trade show. Attendees can meet with 1,300+ suppliers, discover innovative solutions, and find the tools to improve productivity and increase profits. There is no better opportunity to network, share knowledge and explore the latest technology.
United Grinding North America announced today the expansion of their extensive range of grinding and measuring equipment with seven new products being unveiled by three of the company's brands.
Recognizing the role robotics plays in adding efficiency and lowering production costs for manufacturers of all types and sizes, Suhner continues to expand its robotics offering. The fully electric EFC-02 delivers precise, constant force throughout robotic grinding, sanding and deburring processes—resulting in superior, consistent surface quality.
Gear hobbing and power skiving processes can be used on the Gleason 100PS, including additional processes like brushing and/or turning operations. Due to the unique flexibility of the 100PS, all gears of a typical e-bike transmission can be produced on a single machine.
SAACKE Precision Tools and Grinding Machines, a family business started in 1892, has announced a Mr. Georg Saacke as president to lead a new management team.
Gleason's e-Drive Days online webinar addresses the specific requirements and challenges of e-Drive transmission manufacture, with particular attention to minimizing gear noise. The event showcases the latest developments in design, simulation, cutting and hard finishing, as well as suitable inspection and analysis tools to achieve most efficient and quiet gears. Day one examines gearbox design and optimization; day two looks at the manufacturing of e-Drive gears; day three offers in-process inspection and gear noise analysis.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our seventh installment online is an interview with Kika Young, president, and Jared Lyford, director of manufacturing operations at Forest City Gear (FCG).
The trend towards hard fine finishing of gears for automotive transmissions is accelerating. In recent years, the focus has been on increasing the efficiency of gears in order to make optimum use of the narrow gear ratio range, gear by gear, and to reduce fuel consumption. Surface finish, in particular, is under increased scrutiny since it plays such a decisive role in achieving the noise and efficiency requirements of gear units for today’s EV applications.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our sixth installment online is an interview with Shane Hollingsworth, vice president of sales, Kapp Technologies.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our fifth installment online is an interview with Adam Gimpert, president, Helios Gear Products.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our fourth installment online is an interview with Scott Knoy, vice president of sales at Nidec Machine Tool America.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our third installment online is an interview with Peter Wiedemann, managing director, Liebherr-Verzahntechnik GmbH and Scott Yoders, vice president sales, Liebherr Gear Technology, Inc.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our second installment online is an interview with Christof Gorgels, vice president, innovation and technology at Klingelnberg.
United Grinding North America announced today the expansion of their distribution network with the addition of Intermaq, a leader in the machine tool industry in Mexico. Intermaq will represent the full line of equipment offered by United Grinding North America and will be instrumental in expanding the footprint of the precision CNC grinding market in Mexico.
State of the Gear Industry Perspectives takes an in-depth look at the challenges and opportunities in gear manufacturing today and in the future. Our first installment online is an interview with Udo Stolz, vice president of sales and marketing at Gleason Corporation.
With expert presentations, live demonstrations and the latest digitalization solutions, the 2023 Liebherr Skiving Day is once again the focal point when it comes to all things gear skiving.
Bharat Gears Ltd., one of India’s largest gear manufacturers, has successfully retrofitted a Reishauer RZ361A gear grinding machine with an advanced NUM Flexium+68 CNC system.
JTEKT recently demonstrated a new double-disc horizontal grinder that simultaneously grinds both sides of silicon wafers to +/- 1 micron from as-sliced condition. The DXSG320 performance represents a massive improvement in accuracy and productivity over the single-spindle vertical grinders common in the chip industry today which grind to 3-4 microns, according to the company.
STUDER focuses on universality and speed with the uniLoad loading system. The automatic loading system enables users of the S31 and S33 external cylindrical grinding machines to increase quality and productivity.
The Machine Training Center (MTC) of Liebherr-Verzahntechnik GmbH in Kempten offers bright training rooms equipped with the latest technology the world of gear making has to offer including an LC 280 gear cutting machine with ChamferCut device, an LGG 280 gear grinding machine and a WGT measuring machine.
Explore gear grinding processes, machine kinematics and set-up, pitfalls, failures and expectations related to finish ground gearing. Learn definitions of gearing component features, process steps from blanking, through heat treatment to finished part ready to ship. Study aspects of Quality Assurance, Inspection Documentation and corrective actions for measured non-conformances. Understand pre-heat treat, heat treatment and post-heat treatment operations including the hows and whys to produce finished gears that conform and perform to end user expectations.
Integrated manufacturing solutions for machining processes from the blank to the finished workpiece are the focus of the DVS TECHNOLOGY GROUP's trade fair appearance at the world's leading trade fair for metalworking IMTS 2022 in Chicago.
IMTS 2022 will host a variety of technologies that will set the tone for manufacturing innovation in the years to come. At the forefront is the integration of data for process control, providing outstanding solutions to manufacturers. Wenzel America and Nidec’s collaboration started with the mutual drive for serving their customer with excellence through data management.
Oelheld US will be located in Booth #237475 in the North Hall. Oelheld technical experts will be on hand to discuss grinding, erosion, precision machining, and filtration, among other topics.
Forming tools are expensive, often made from carbide and tool steel. Carbide grinding is often the first choice today because customer requirements have increased and continue to increase in terms of complexity, dimensional accuracy and reproducibility. Apart from that, production must also be significantly more economical.
System-supplier Klingelnberg will be back at AMB (Booth C41, Hall 5), where it will be highlighting solutions for smooth-running gearboxes. The exhibit will feature the Höfler Cylindrical Gear Grinding Machine Speed Viper, the Klingelnberg Precision Measuring Center P 40 and the newly developed Höfler Cylindrical Gear Roll Testing Machine R 300.
EMAG will highlight productive, and at the same time, flexible manufacturing solutions for electromobility at IMTS. Among other things, the focus is on the vertical pick-up lathes of the VL series, which EMAG now delivers IoT-Ready.
When it comes to an early identification of noise problems in the drivetrain one has to take data analytics and its integration in the manufacturing process into account. The big vision here, in particular, is preventive quality. By evaluating sensor data of the machining process, it promises to predict whether a gear is ok or not ok.
In acquiring the Turkish Egeli Egesan Group the Tyrolit Group continues to implement its business expansion strategy and has further strengthened its position on the international abrasives market.
Kennametal has introduced the new Grooving Universal Positive Profiling geometry (GUP-V), expanding on its Beyond Evolution grooving & cut-off platform. With the addition of the new V-shaped single-sided insert, Beyond Evolution can cover now more applications than ever and helps to save tooling cost.
When Sandvik Coromant opened its new Center Mebane facility last year in Mebane, NC, near Raleigh the vision was to use it as a hub for training, R&D testing, customer projects and, most of all, an opportunity for comprehensive customer and partner engagement.
Klingelnberg will be featuring the latest gear production, calculation and measuring technologies during IMTS in Booth #236935.
Liebherr Gear Technology will be displaying a variety of technologies at Booth #236914 (North Hall) during IMTS 2022.
The MAZATROL SmoothEz CNC from Mazak has a graphical, intuitive programming mode that minimizes the use and understanding of G-codes. Users answer conversationally displayed questions about the workpiece, and the control constructs the program automatically.
Star Cutter Company will be displaying its newest generation automated NXT 5-axis tool grinder in Booth #237013 at IMTS 2022 featuring detailed graphics that enable visitors to take a self-guided tour of the machine, which will be shadow grinding during the show. The display system will feature the 28 kW spindle option and four-station wheel change capability. It will be equipped with a robot loader and flat blade/insert clamping fixture for live demonstration of automated production. Videos to showcase tooling for form cutters, boring bars and medical hip rasps will also be on display.
At IMTS 2022, United Grinding North America will be featuring the STUDER S131r cylindrical ID-radius grinding machine for I.D. grinding operations where maximum precision is paramount.
Effective June 1, 2022, Index has established a dedicated service department to rebuild tool holders at its North American headquarters in Noblesville, Indiana. Previously, the company processed all such rebuilds at its parent company in Germany. By investing in bringing this capability to the United States, Index expects to cut lead times for rebuilds by 50% - 70%.
The way to increase production, especially with the largest gears, is to decrease nonproductive time with improved strategies.
Nidec Machine Tool (Wixom, Mich.), responding to the needs of the industry, is debuting the new GE15HS gear hobbing machine at IMTS 2022 in Booth #237036. Emphasizing high speed, precision and efficiency, the new machine produces gears for electric and hybrid cars, as well as for robotic and automation applications.
It is with great sadness Gleason Corporation announces the passing of James S. Gleason, a Gleason board member and former chairman and CEO of the company who died on June 17th at the age of 88 years old. Jim, a great grandson of the company’s founder William Gleason, contributed to the company in various roles, continuing to serve as a director on the board up until his death.
At IMTS 2022, Norton ׀ Saint-Gobain Abrasives (Booth #237042, North Hall) will offer a portfolio of gear grinding products specifically designed by category to provide higher profile accuracy, supreme form holding and burn-free grinding in worm, profile, and bevel applications. Highlighting the range is an innovative dual-worm wheel design that enables two operations in one grinding wheel, substantially saving time and cost.
Marposs has announced the acquisition of Jenoptik’s (Jena, Germany) non-optical process measuring technology business for grinding machines, formerly known as Movomatic.
DMG MORI’s new Technology Center in the heart of Somerville, in Northeast USA, will be a hub for research and development of new digitization solutions and processes for customers worldwide.
Within the last decade, hard finishing technologies become highly relevant. Increasing the power density of a gearbox requires precisely machined gears without heat distortions. Especially in noise-sensitive applications, both honing and grinding are often applied.
Watch an installation of a ZP 20 gear profile grinding machine from Kapp Niles.
As a result of its recent partnership with S.F.H., Jorgensen Conveyor and Filtration Solutions now serves manufacturers as a single source for total metalworking chip and coolant processing systems. With standalone or fully integrated systems that transport, shred, wring and briquette chips and sludge, manufacturers can reduce chip volumes by as much as 90% and significantly increase their chip recycling value.
The WFL Technology Meeting takes place June 21-23, 2022. Visitors can look forward to expert discussions on the latest industry trends and developments. Highlights during the event include machine demonstrations, measurement technologies, automation solutions and more.
The Haas Booth C50 Hall 10 at GrindingHub will include the Multigrind Radical, Multimation and the Multigrind CB XL series. In addition, the Multigrind CU, the Multigrind CA and the Multigrind CB will be featured during the show.
The automotive industry is evolving. The trend toward more electromobility is also changing the way cars are being manufactured. In some cases, this has a serious impact, not only on automakers themselves, but also on suppliers. Jürgen Hechler, Global Application Engineering Leader at 3M, is nevertheless confident: "We expect the demand for high-precision abrasives to continue to grow, despite the discussion about electromobility." Among other things, 3M supplies the automotive industry with abrasives for machining gears and shafts.
Fully electric vehicle drives usually require two-stage, non-switchable transmissions. One would think that this greatly simplifies the production. Finally, the described transmission structure has just four gears, distributed on the drive shaft, the second stage with fixed wheel and intermediate shaft as well as the axle drive wheel. But the conditions are not that simple: First of all, the engine speeds of the electric drive with up to 16,000 rpm are much higher than those of the combustion engine. For this purpose, electric motors deliver an almost constant torque over a wide speed range. Unlike the combustion engine, it is already attached to the transmission from zero speed. In addition, there is an additional boundary condition that makes production much more demanding than with the conventional powertrain.
Weiler Abrasives has announced the availability of its Tiger abrasives line designed to deliver maximum performance in the most demanding foundry applications. With solutions to address all grinding applications in the cleaning room, Tiger products help decrease cycle times and improve operator experience.
The Kapp Niles KX 300 P gear center offers machining flexibility due to various machining processes. The machine features direct drives in both the tool and workpiece spindles.
US Grinding Days Seminar (3M and Liebherr) is a two-day program designed to provide attendees with industry insights into the latest gear grinding methods, technology, and related topics.
Many see the fluids as an unnecessary evil to the grinding process, failing to realize that selecting the right grinding fluid can lead to significant improvements in cycle time, surface quality, finishes, secondary operations, such as tool coatings. Oelheld has put together a short article on grinding oil considerations.
Weiler Abrasives is pleased to announce that Karl M. Weiler, former president, has received the John J. Buckley Lifetime Achievement Award from the Industrial Supply Association (ISA).
Tremec and Klingelnberg have been working together with regard to tool and gear measuring machines since 1993. They recently collaborated on transmission technology with Speed Viper machine tools.
The Kapp Niles ZX series provides high-end productivity, even for bigger gears and larger modules. It is driven by an electrical high-accuracy direct drive, providing a high level of positioning accuracy even for the profile grinding process.
The Digital Manufacturing Revolution Evolves in 2020 IMTS will offer two comprehensive digital programs, IMTS Network and IMTS Sp...
One of the problems with “tribal knowledge” is that the terminology can confuse those who are not fully immersed in that community. I have lost ...
“All memorable quotations referring to gearboxes involve expletives.” Peter Wright The author of Fo...
