Precision regrinding leaves no room for error. At Fraisa, direct data transfer between Zoller measurement systems and ANCA’s WheelServer ensures every grinding wheel pack is ready to perform—no guesswork, no rework. The result: 20 percent less downtime, 10 percent less rework, and consistently perfect tools on the first try.
Injection molding bridges prototyping and full-scale production with its unmatched scalability and precision. By integrating CT technology, manufacturers gain clear insights into mold accuracy and material behavior—accelerating the path from design to high-volume, defect-free plastic parts.
Is your grinding or finishing process optimized for maximum efficiency? The Weiler Process Solutions (WPS) evaluation helps gear manufacturers to enhance productivity, reduce costs, and improve safety. Our expert team will assess your operation and recommend tailored solutions to optimize performance. Sign up for a free evaluation today, and we’ll contact you within 48 hours to discuss how we can help—potentially visiting your site for a hands-on assessment.
This year marks an important milestone as Gleason Corporation celebrates its 160th anniversary. Founded in 1865 by William Gleason, the company has transformed from a small workshop to a global leader in gear technology, offering comprehensive solutions that encompass design software, manufacturing and metrology equipment, tooling, aftermarket services, and an extensive training program.
This article requires that the reader be familiar with Job Shop Lean, an approach to adapt the principles of lean manufacturing for a job shop, regardless of its size or industry sector. A job shop typically executes a different schedule every day. Each day’s schedule could have a different mix of jobs, due dates, lot sizes, and number of gear operations. Regardless of all these differences, it is important that the shop receives a feasible schedule that does not exceed available capacity constraints on key resources (machines, labor, materials, dies, etc.).
Heidenhain Corporation announces its participation at the Southtec trade show, scheduled from October 24–26, 2023, at the Greenville Convention Center in Greenville, SC.
We came across an interesting statistic recently in our normal product coverage for Gear Technology magazine. United Grinding had more than 2,500 remote deployments during the pandemic. Digital assistance systems—big and small—helped machine operators navigate production output in real time during this chaotic work period.
Verisurf Software, Inc. will be demonstrating a universal approach to measurement and inspection at this year’s IMTS Show in Booth #133345. Verisurf software provides measurement and inspection workflows with inspection plans that can be created once and used across the manufacturing enterprise on any portable or fixed CMM.
“It appears that undercut can be eliminated in some cases but in most cases, the elimination of undercut, for example by increasing the root fillet radii of a pinion, results in performance problems in the operation with its mate. My question is, when can I eliminate undercut and why is it not possible in most cases?”
This report focuses on the combined consideration of the infeed and the subsequent axial machining with additional variation of the workpiece width in order to evaluate the influence of the infeed with increasing or decreasing full cut area.
Since the macro geometry of bevel gears is directly dependent on the manufacturing process, there are limitations in the combination of pre-machining and hard finishing processes which are related to the geometry of the gaps.
It’s getting complicated. First it was the Amazon packages dropping into the backyard via an unmanned vehicle. This was followed by numerous companies working on autonomous vehicles for buses, taxis and even two-seater air shuttles. Now, a prototype unmanned aerial tanker refueled a F/A-18F Super Hornet fighter jet in early June. That’s right—a drone just refueled a fighter jet in mid-air.
How the increasing demands on power transmission and reduction in mass of modern gearboxes lead to gear designs that are close to their load-carrying capacity limits.
Reader Survey Results. Gear Technology's annual State-of-the-Gear-Industry survey polls gear manufacturers about the latest trends and opinions relating to the overall health of the gear industry. As in years past, the survey was conducted anonymously, with invitations sent by e-mail to gear industry companies – primarily in North America, but also including some respondents from around the world.
A visit to the HMC Gears plant in Indiana kicked off an extensive project which resulted in the creation of a unique solution for exceptional demands: With the LC 4000, Liebherr forges new paths in large-scale gear cutting production and unites diverse machining methods in one highly efficient
machine for the American gear specialist.
All cutting and machining operations produce some type of burr or leave sharp edges on metal components. These unwanted byproducts are especially troublesome when producing precision components such as gears. The burrs can loosen from
the gear - either during assembly or later when the gear is in operation - and damage components or lead to critical part failure.
20/20 is considered to be perfect vision, but the year 2020 outlook is quite obscure. We can view the current state of the PM industry through short-term, fear-tinted glasses or gain a clearer picture of long-range opportunities. Just like U.S. manufacturing in general, the PM industry has been impacted negatively by the pandemic.
How does one select the correct size of hob/gashing cutter like hob OD,
length and number of flutes for teeth cutting process based on tip circle
diameter and face width of job?
Italian gear manufacturer Metalcastello’s investment in new Gleason Power Skiving technology gives the company a strong competitive edge as the world’s industries
gear up for the post-pandemic.
Due to production by pressing and sintering, PM gears are porous. Since pores reduce the loaded area and are also probable crack initiators, the porosity determines the strength of the PM component. PM gears can be densified to increase their local density and, therefore, the load-carrying capacity. PM gears are compacted locally since they are mainly loaded directly at the surface. A common process to densify PM gears locally is the cold rolling process. The contact conditions in the cold rolling process determine the density profile and, therefore, the material properties of the PM component. The influence of the contact conditions in cold rolling of PM gears on the resulting density profile is yet to be investigated.
Spur cylindrical gears are usually cut using a hob and therefore present an essentially straight face to which crowning can be added to prevent edge contact. Rather than using a rack or hob, it is possible to cut cylindrical gears with a face mill cutter. In the following presentation, these gears are termed "spurved," i.e. — a contraction of "spur" and "curved."
The wear behavior of polymer gears made of five different materials has been investigated using an existing polymer gear test rig. Step loading tests at a constant speed of 1,000 rpm were performed. Significant differences in failure modes and performance have been observed for the five polymer gear materials for gear engagements of gears, with the same material as each other.
This article provides a guideline for the selection of a suitable standard in connection with the kind of spline to be designed and manufactured. Some basic formulae have been explained, together with a strategy on how to find standard
tooling by calculating an appropriate profile shift factor for the spline to be designed.
Forest City Gear makes the investment
to bring gear blanking in-house, giving it
complete control over quality and delivery: because failure’s not an option.
Mitsubishi Heavy Industries, Ltd. (MHI) conducted a comparison test between the super skiving cutter and the pinion skiving cutter used in the conventional skiving process and the test results are reported here.
Experiencing a Dickensian dilemma in its essence, a Los Angeles based manufacturing company was faced with the good fortune of ever increasing orders for steel gears from a good customer with a new recreational product in very high demand. Confronting the possibility of an untold number of lonely late nights tending to the whims of a 1950s era manual hobber was an
unpalatable prospect no one desired.
Another young man discovers you need not be an expert machinist to succeed as a gear engineer. Spoiler alert: never tangle with a grinding wheel; they are undefeated in all time.
One way to implement the growing performance requirements for transmissions is by optimizing the surface finish of the gearing. In addition to increasing the flank load capacity and the transmittable torque, this also allows for improvements in efficiency. On Oerlikon bevel gear grinding machines from Klingelnberg, fine grinding
can be implemented efficiently in bevel gear production - even in an industrial serial process.
Gear honing is a highly productive process for the production of small and
medium sized gears and is used mainly in the serial production of the automotive
industry. The low robustness of the process is a particular challenge in gear
honing. The consequences range from an inadequate gear quality to an early breakage of the honing tool. In order to describe the processmachine interaction, the machining forces must be known.
This paper outlines the basic principles of involute
gear generation by using a milling cutter;
the machine and cutting tool requirements; similarities
and differences with other gear generative methods; the cutting strategy; and setup adjustments options. It also discusses the applications that would benefit the most: for coarse-pitch gears the generative gear milling technologies offer improved efficiency, expanded machine pitch capacity, decreased cutter cost, and a possibility for reducing the number of machining operations.
Automotive gear manufacturers have implemented significant improvements in external planetary gear manufacturing yielding quieter gears. In addition, process stability has increased due to the post-heat treatment finishing processes employed. This article explains various complete solutions for cutting and finishing internal ring gears.
Gear skiving is here to stay, and as a result of this industry shift, it’s become paramount to improve how well machining spindles synchronize with each other.
Cubic Boron Nitride (cBN) abrasive wheels, which are a specially engineered abrasive grain referred to as a superabrasive, typically yield 2,200 - 2,500 parts per dress with one wheel lasting as long
as four to six months.
To achieve the requested quality, most gears today are ground. The usual grinding process includes treating the gear flank but disengaging before reaching the root rounding area. If the gear is premanufactured with a tool without protuberance, then at the position where the grinding tool retracts from the flank a grinding notch in the tooth root area is produced. Such a notch may increase the bending stresses in the root area, thus reducing the strength rating.
Electrification has already started to have a noticeable impact on the global automotive industry. As a result, the drivetrains of hybrid (HEV) and full electric vehicles (EV) are facing many challenges, like increased requirements for NVH in high speed e-Drives and the need for performance improvements to deal with recuperation requirements. Motivated by the positive validation results of surface densified manual transmission gears which are also applicable for dedicated hybrid transmissions (DHTs) like
e-DCTs, GKN engineers have been looking for a more challenging application
for PM gears within those areas.
Powder metal (PM) gears normally sell due to the lower cost and their relatively high mechanical performance. The reason behind the lower cost is that most of the machining is omitted due to the net-shape forming process. So how net-shape are powder metal gears? In this article some hard-to-find information about the tolerances through the manufacturing steps will be presented.
The properties of both shot-peened and cold rolled PM gears are analyzed and
compared. To quantify the effect of both manufacturing processes, the tooth root
bending fatigue strength will be evaluated and compared to wrought gears.
Chamfering and deburring have been described as "unloved," a "necessary evil" and, in fact - "dead." After all, manual deburring is still common in many shops.
Deburring or chamfering of gear teeth is gaining attention in practical settings. And with a view to make the production sequence as efficient as possible, it is becoming increasingly important to be able to implement the deburring tasks directly on the cutting machine after spiral cutting.
The first planetary drive I helped take apart had three stages of through hardened spur gears encased in a simple cast iron tube with plates on both ends. Both input and output shafts rotated on taper roller bearings, but everything else had simple bronze bushings.
With increasingly smaller returns from improving the speed of the actual gear grinding process, improving your setup time has become a primary way to keep improving efficiency. Here's the latest on how you can do that today.
"Documentation is not a Substitute for an Intuitive Interface." The author explores the development of modern controls for a CNC gear grinding machine.
Back around 2005-2010, the most exciting things that were happening in broaching had little to do with broaching. What
was happening - and continues to
evolve today - was the emergence of on-the-edge CNC, software and servo drive
technology. Together, they practically
transformed a metalworking process as
old as water into a viable, alternative
consideration for producing high-volume
part runs.
It's probably no surprise to anyone that the majority of the gear industry had a pretty good
year in 2017, and that most gear manufacturers are expecting a pretty good 2018 as well. After
all, most major economic indicators - including the ones that focus on the manufacturing sector - have been positive for some time.
The DVS gearing specialist Praewema Antriebstechnik continues to expand its technological expertise in order to keep pace with the growing significance of planetary geartrains for automatic and particularly electric vehicles, with the associated need for even higher-precision production of toothed gear components.
Business is finally starting to get back to usual in the big gear world, which offers us a chance to look back at the greatest lesson on how to survive an economic downturn. Includes the sidebar: "Brass Tacks with Klingelnberg."
Call it new wine in old bottles, or old wine in new bottles, but
gear skiving has certainly aged well over time. Gear skiving's evolution, perhaps gaining momentum most dramatically since around 2004, has ultimately led to rather dramatic technological advancement and cost saving in the manufacture of certain gears.
You get one shot to make a first impression. One opportunity to show your customers, vendors and suppliers that you provide a steady, reliable product that will generate repeat business. How do you make this happen? What tools and strategies are available to get gear materials (forgings, gear blanks, etc.) shipped faster and more efficiently in today's tech-heavy, fast-paced, manufacturing environment?
Gear Technology hosts dinner for technical contributors to the gear industry during this year's AGMA Fall Technical Meeting and Gear Expo in Columbus, OH. Plus other news from around the industry.
First, the facts: powder metallurgy is a cost-effective method of forming precision net-shape metal components that allows for more efficiently designed products. It saves valuable raw materials through recycling and the elimination of costly secondary-machining. PM competes with wrought steel gears as the technology continues to advance. You'll find PM components in everything from automobile transmissions to aircraft turbine engines, surgical equipment and power tools.
When manufacturing powder metal (PM) gears lead crowning is not achievable in the compaction process. This has to be accomplished either by shaving, grinding or honing. Each of these processes has their merits and draw backs. When employing rolling using a roll burnishing machine lead crowning can be accomplished but due to errors in profile a hard finishing operation such as grinding is used by the industry. In this paper a helical PM gear that has sufficient tolerance class after rolling has been tested in a test rig for durability and the wear has been studied.
RCD Engineering's switch from manual to CNC hobbing operations breaks gear manufacturing lead time records with
Bourn & Koch 100H in their gear production pit crew.
Skiving will be front and center when the gear industry comes together in Columbus this October. Attendees will find dedicated skiving equipment, multifunctional machines with skiving options and a slew of new cutting tools, machine designs and modifications to make the process more efficient and robust.
Toyoda's new GS300H5 Gear Skiving Center is the first in the world to equip a skiving function to a general purpose horizontal machining center (HMC), through which mass production of gear parts is achieved. CNC controls and a high speed rotary table were developed specifically to achieve high-speed, multifunctional machining, as a compact and lightweight product, simple in programming functions.
Gear hobbing is one of the most productive manufacturing processes for cylindrical gears. The quality of the gears is a result of the tool quality, the precision of the workpiece, tool clamping and kinematics of the machine. The dry gear hobbing process allows machining of gears with a quality according to the DIN standard up to IT 5. To evaluate which gear quality is possible to machine with a given clamping and hob, it is useful to simulate the process in advance.
New divisions, open houses and the continued rise of the Industrial Internet of Things - There's been a lot going on in gear grinding in the past year.
A reader wants to know: Are profile ground and hobbed globoidal worm sets better than multi-axis CNC generated globoidal worm gear sets for reduction of noise and vibration?
Exciting new machine, cutting tool and software technologies are compelling
many manufacturers to take a fresh look at producing their larger gears on machining centers. They're faster than ever, more flexible, easy to operate, highly affordable - and for any type of gear.
Free form milling of gears becomes more and more important as a flexible machining process for gears. Reasons for that are high degrees of freedom as the usage of universal tool geometry and machine tools is possible. This allows flexible machining of various gear types and sizes with one manufacturing system. This paper deals with manufacturing, quality and performance of gears made by free form milling. The focus is set on specific process properties of the parts. The potential of free form milling is investigated in cutting tests of a common standard gear. The component properties are analyzed and flank load-carrying capacity of the gears is derived by running trials on back-to-back test benches. Hereby the characteristics of gears made by free form milling and capability in comparison with conventionally manufactured gears will be shown.
Oil-out conditions, or conditions
in which an aircraft is
operating without any oil in its
gearbox or transmission, are
devastating for an aircraft's
hardware. Even the sturdiest gears
usually can't last 30 minutes under such
conditions before they catastrophically
fail, and the whole system usually follows shortly after. That doesn't leave pilots with a whole lot of time to find a suitable location to land in the case of an oil-out emergency.
What is the best tooling to use when hard milling a gear tooth on a 5-axis machining center? And what makes it the best? We have just bought a DMG Mori mono-block and are not getting the finishes at the cycle times we require.
Attached photos (Figs. 1-2) show a
bushing to locate one single bore. This
will be used to locate one single bore
diameter of a gear wheel. What is (the
latest) technology for common clamping a
bushing to locate multiple bore diameters
in hobbing?
Excessive machine tool vibration during a precision grinding operation can result in poor workpiece quality in the form of chatter, rough finishes, burn, etc. One possible reason for
excessive vibration is directly associated with the relationship
between natural frequencies of a machine tool system and the
operating speed of the grinding wheel spindle.
During a year with a strong
dollar, tanked oil prices and a
number of soft markets that
just aren't buying, one might
expect spline manufacturers
to be experiencing the same
tumult everyone else is. But when
I got a chance to speak with some of
the suppliers to spline manufacturers at
IMTS about how business is going, many
of the manufacturing industry's recent
woes never came up, and instead were
replaced by a shrug and an "eh, business
is doing pretty well."
I make all the double helical gears that go into a gearbox - four
different gears in this unit. If the gear module for the bull gear and the
intermediate gear are the same (these are the two individual gears that
mate), and the gear module for the high-speed pinion and high-speed
gears are the same (these are the other two individual gears that mate
in the gear box as well), is it then possible to just use two hobs in this
setup to make all four gears, since they mate together with each other?
We are currently using a different gear hob for each gear.
Chamfering and deburring of
cylindrical gears does not get
much love from manufacturers.
The process is seen as a necessary evil
since it is adding cost without adding
value. However, there are good reasons
for not underrating this important auxiliary
process. Chamfering and deburring
takes care of several issues which
may come up during the manufacture of
quality gears.
Broaching is a machining technique commonly used to cut gear teeth or cam profiles for the high volume manufacture of power transmission parts used in vehicles (Refs. 1–2). This article shows how the right gear blank material can make all the difference if you want to get more parts out of each tool.
While designing gear and spline teeth, the root fillet area and the corresponding maximum tensile stress are primary design considerations for the gear designer. Root fillet tensile stress may be calculated using macro-geometry values such as module,
minor diameter, effective fillet radius, face width, etc.
THE FINAL CHAPTER
Looking for some simple yet useful advice heading into IMTS 2016? Never second guess your machine tool investment. Flexibility is a
mandatory requirement in gear manufacturing today. Accuracy, reliability and efficiency must improve with each new machine tool purchase. Innovation is always the end game. So it comes as no surprise that IMTS 2016 attendees will have plenty of gear grinding technologies
to consider this fall.
Plastic gears are everywhere
The 2015 Gear Technology Buyers Guide
was compiled to provide you with a
handy resource containing the contact
information for significant suppliers of
machinery, tooling, supplies and services used in gear manufacturing.
Hard finishing technology, e.g. — honing — is used to manufacture high-performance gears. Gear honing is primarily used to hard finish small- and medium-sized automotive gears. And yet trials have shown that gears with a module larger than mn = 4 mm can also be honed efficiently, but problems often occur due to unstable process design. In this paper a model to improve the process design is described.
I would like some instructions for setting the degrees and minutes on a Liebherr
or Barber Colman hob. Our machines use a Vernier scale to match the lead angle
of the cutter to the part to form straight teeth. There is a dispute on how to do
this task, and I wanted insight from another professional.
Generating gear grinding is one of the most important finishing processes for small and medium-sized gears, its process design often determined by practical knowledge.
Therefore a manufacturing simulation with the capability to calculate key values for the process — such as the specific material removal rate — is developed here. Indeed, this
paper presents first results of a model for a local analysis of the value. Additionally, an empirical formula — based on a multiple regression model for a global value describing the process — is provided.
I have outsourced gear macrogeometry due to lack of resources. Now I received the output from them and one of the gears is with —0.8× module correction factor for m = 1.8 mm gear. Since bending root stress and specific slide is at par with specification, but negative correction factor —0.8× module — is quite high — how will it influence NVH behavior/transmission error? SAP and TIF are very close to
0.05 mm; how will that influence the manufacturing/cost?
Many years ago, when asked how the
five-meter gear was checked, the quality manager responded, “When they’re that big, they’re never bad!” That may have been the attitude and practice in the past, but it no longer serves the manufacturer nor the customer. Requirements have been evolving steadily, requiring gears to
perform better and last longer.
Developed here is a new method to automatically find the optimal topological modification from the predetermined measurement grid points for bevel gears. Employing this method
enables the duplication of any flank form of a bevel gear given by the measurement points and the creation of a 3-D model for CAM machining in a very short time. This method not only
allows the user to model existing flank forms into 3-D models, but also can be applied for various other purposes, such as compensating for hardening distortions and manufacturing deviations which are very important issues but not yet solved in the practical milling process.
When Dr. Hermann J. Stadtfeld speaks,
people tend to listen.
Considered one of the world’s foremost
experts on bevel gears, Stadtfeld,
the vice president of bevel gear technology at Gleason, recently revealed several cutting-edge advancements that the company has been working on.
Liebherr is well-known as one of the world’s largest privately owned companies — a titan in heavy industry specializing in cranes, trucks and mammoth earth moving and mining
equipment.
The question is quite broad, as there
are different methods for setting various types of gears and complexity of
gear assemblies, but all gears have a few things in common.
In 1964, a young and tidy Bob Dylan sang away in that infamous voice of his,
all nasally and grating yet wonderfully distinct, opining to the fervent masses: “The times, they are a-changin.”
This paper presents the geometric design of hypoid gears with involute gear teeth. An
overview of face cutting techniques prevalent in hypoid gear fabrication is presented. Next,
the specification of a planar involute rack is reviewed. This rack is used to define a variable
diameter cutter based upon a system of cylindroidal coordinates; thus, a cursory presentation
of cylindroidal coordinates is included. A mapping transforms the planar involute rack into a variable diameter cutter using the cylindroidal coordinates. Hypoid gears are based on the envelope of this cutter. A hypoid gear set is presented based on an automotive rear axle.
The process of forging metal into shapes possesses
a surprisingly long and storied history.
For example, the method of hot rolling can trace its protracted existence all the way back to an enigmatic Italian polymath named Leonardo da Vinci (you may have heard of him), who reportedly invented the rolling mill one lazy day in the 1400s.
At the dawn of the Industrial
The recently available capability for the free-form milling of gears of various gear types and sizes — all within one manufacturing system — is becoming increasingly recognized as a flexible machining process for gears.
The holiday gift catalogs have started to arrive at my house. Over the years our gift list has been pared down, but we occasionally see something unique that is just perfect for someone on the list.
The hobbing and generation grinding production processes are complex due to tool geometry and kinematics. Expert knowledge and extensive testing are required for a clear attribution of cause to work piece deviations. A newly developed software tool now makes it possible to simulate the cutting procedure of the tool and superimpose systematic deviations on it. The performance of the simulation
software is illustrated here with practical examples. The new simulation tool allows the user to accurately predict the effect of errors. With this knowledge, the user can design and operate optimal, robust gearing processes.
The honing of gears - by definition
- facilitates ease of operation, low noise and smoother performance in a transmission. Honing also contributes to
reduced friction in the powertrain. Both the intense cutting (roughing process) as well as the functionally fine- finishing of transmission gears can be performed in one setup, on one machine.
For maximum life in carburized and ground gearing, I have been advised that fully grinding a radius into the root gives maximum resistance against fatigue failures. Others have advised that a hobbed and unground radius root form is best. Which is best, and why?
In order to produce high-performance cutting tools, tool manufacturers go to great lengths to get all manufacturing parameters right. Production conditions have tremendous influence on the final quality of the tool...
Sunnen's new HTE honing system, the company's most cost-effective small-diameter hone, produces ideal bore geometry and surface finish, while eliminating problems from bad tool-to-part alignment...
Decades ago, technology shifted from HSS to indexable inserts in turning and milling. This movement wasn't immediately realized in gear hobbing because coated PM-HSS hobs and complex gear profiles remained highly effective and productive methods. Only fairly recently have gear manufacturers started to take a serious look at indexable technology to cut gear teeth.
The long and colorful history of aviation is comprised of many chapters and giants. The chapter we're reviewing in this installment of Addendum is the invention and development of the retractable landing gear.
Sunnen Products Company introduces a quantum improvement in a key manufacturing process for cast-iron hydraulic valve bodies using a precision single stroke honing process...
Affolter Technologies SA presents its most recent innovation. "The GEAR AF110 sets a new benchmark in regards to flexibility, high precision and stiffness...
Every so often manufacturing is jolted out of its inertia by a transformative technology – one that fundamentally changes not only the way products are made, but also the economics of the business.
The grinding/abrasives market is rapidly changing, thanks to new technology, more flexibility and an attempt to lower customer costs. Productivity is at an all-time high in this market, and it’s only going to improve with further R&D. By the time IMTS 2014 rolls around this September, the gear market will have lots of new toys and gadgets to offer potential customers. If you haven’t upgraded any grinding/abrasives equipment in the last five years, now might be a good time to consider the investment.
The heat treatment processing of powder metal (PM) materials like Astaloy requires four steps -- de-waxing, HT sintering, carburizing and surface hardening -- which are usually achieved in dedicated, atmospheric furnaces for sintering and heat treat, respectively, leading to intermediate handling operations and repeated heating and cooling cycles. This paper presents the concept of the multi-purpose batch vacuum furnace, one that is able to realize all of these steps in one unique cycle. The multiple benefits brought by this technology are summarized here, the main goal being to use this technology to manufacture high-load transmission gears in PM materials.
Dressable vitrified bond CBN grinding tools combine the advantages of other common tool systems in generating gear grinding. Yet despite those technological advantages, there is only a small market distribution of these grinding tools due to high tool costs. Furthermore, scant literature exists regarding generating gear grinding with dressable CBN. This is especially true regarding the influence of the grinding tool system on manufacturing-related component properties. The research objective of this report is to determine the advantages of dressable CBN tools in generating gear grinding.
It's not easy being big. Maybe that's not exactly how the phrase goes, but it's applicable, particularly when discussing the quality requirements of large gears. The size alone promises unique engineering challenges. BONUS Online Exclusive: Big or Small - Inspection is Key to Success.
It has long been known that the skiving
process for machining internal gears is
multiple times faster than shaping, and
more flexible than broaching, due to skiving's continuous chip removal capability. However, skiving has always presented a challenge to machines and tools. With the relatively low dynamic stiffness in the gear trains of mechanical machines, as well as the fast wear of uncoated cutters, skiving of cylindrical gears never achieved acceptance in shaping or hobbing, until recently.
Much of the existing guidelines for making large, high-performance gears for wind turbine gearboxes exhibit a need for improvement. Consider: the large grinding stock used to compensate for heat treatment distortion can significantly reduce manufacturing productivity; and, materials and manufacturing processes are two other promising avenues to improvement. The work presented here investigates quenchable alloy steels that, combined with specifically developed Case-hardening and heat treatment processes, exhibits reduced distortion and, in turn, requires a smaller grinding stock.
Look beyond the obvious, and you may
well find a better way to machine a part,
and serve your customer better. That’s
the lesson illustrated in a gear machining
application at Allied Specialty
Precision Inc. (ASPI), located in Mishawaka, Indiana.
Whether you spent time at Gear Expo in Indianapolis or EMO in Hannover, there was certainly new technology
attracting attention. Machine tools are faster, more efficient and can integrate numerous functions in a single setup. Grinding technology is turning science upside down and inside out with high-speed removal rates and increased throughput.
For metal replacement with powder metal (PM) of an automotive transmission, PM gear design differs from its wrought counterpart. Indeed, complete reverse-engineering and re-design is required so to better understand and document the performance parameters of solid-steel vs. PM gears. Presented here is a re-design (re-building a 6-speed manual transmission for an Opel Insignia 4-cylinder, turbocharged 2-liter engine delivering 220 hp/320 N-m) showing that substituting a different microgeometry of the PM gear teeth -- coupled with lower Young’s modulus -- theoretically enhances performance when compared to the solid-steel design.
For two days in Saline, Michigan,
Liebherr's clients, customers and
friends came together to discuss the latest gear products and technology. Peter Wiedemann, president of Liebherr Gear Technology Inc., along with Dr.-Ing. Alois Mundt, managing director, Dr.-Ing. Oliver Winkel, head of application technology, and Dr.-Ing. Andreas Mehr, technology development shaping and grinding, hosted a variety of informative presentations.
This machine concept facilitates highly
productive profile grinding for large workpieces. The range for external and internal gears comprises models for manufacturing workpieces up to 2,000 millimeters – for industrial gear units, wind power, and marine propulsion applications
Hobbing is one of the most fundamental
processes in gear manufacturing. Its
productivity and versatility make hobbing
the gear manufacturing method of choice for a majority of spur and helical
gears.
By virtue of collected anecdotal accounts, equations and problem solving, balancing is discussed as more math and common sense, and less smoke and mirrors.
Following is a report on the R&D findings regarding remediation of high-value, high-demand spiral bevel gears for the UH–60 helicopter tail rotor drivetrain. As spiral bevel gears for the UH–60 helicopter are in generally High-Demand due to the needs of new aircraft production and the overhaul and repair of aircraft returning from service, acquisition of new spiral bevel gears in support
of R&D activities is very challenging. To compensate, an assessment was done of a then-emerging superfinishing method—i.e., the micromachining process (MPP)—as a potential repair technique for spiral bevel gears, as well as a way to enhance their performance and durability. The results are described in this paper.
A high-performance, 11-axis CNC system
from NUM has enabled machine tool
manufacturer Sicmat to create a gear honing machine that sets a new industry standard for post-hardening fine finishing.
Except for higher-end gear applications
found in automotive and aerospace transmissions, for example,
high-performance, sintered-steel
gears match wrought-steel gears in strength and geometrical quality. The enhanced P/M performance is due largely to advances in powder metallurgy over last two decades, such as selective surface densification, new materials and
lubricants for high density and
warm-die pressing. This paper is a
review of the results of a decade of
research and development of high- performance, sintered-steel gear prototypes.
Capstan Atlantic, located in Wrentham, Massachusetts, produces powder metal gears, sprockets and complex structural
components. The company has provided unique powder metal products in a variety of industries including automotive, business machines, appliances, lawn and garden equipment
and recreational vehicles.
years ago.
In today’s manufacturing environment, shorter and more efficient product
development has become the norm. It is therefore important to consider every
detail of the development process, with a particular emphasis on design. For
green machining of gears, the most productive and important process is hobbing. In order to analyze process design for this paper, a manufacturing simulation was developed capable of calculating chip geometries and process forces based on different models. As an important tool for manufacturing technology engineers, an economic feasibility analysis is implemented as well. The aim of this paper is to show how an efficient process design—as well as an efficient process—can be designed.
The objective, according to Dr.-
Ing. Hansjörg Geiser, head of development and design for gear machines at Liebherr, was to develop and design a combined turning and hobbing machine in which turning, drilling and hobbing work could be carried out in the same clamping arrangement as the hobbing of the gearings and the subsequent chamfering and deburring processes.
in this area.
There are a number of companies
working to change the way broaching is perceived, and over the past 10 years, they’ve incorporated significant
technological changes to make the process more flexible, productive
and accurate.
Design innovation, superior engineering properties, high
end-market visibility and sustainability distinguish the winners
of the 2011 Design Excellence awards, the annual powder metallurgy (PM) design competition sponsored by the Metal Powder Industries Federation.
Machine tool companies are expanding capabilities to better accommodate the changing face of manufacturing. Customers want smaller-sized equipment to take up less valuable floor space, multifunctional machines that can handle a variety of operations and easy set-up changes that offer simplified operation and maintenance.
The great thing about a trade show the size of IMTS is the amount of options available to attendees. If you’re into cars, fighter jets, machine tools,
fighting robots, manufacturing relics or
simply the latest technology advancements in a particular industry, you’ll find it at IMTS 2010.
The metal powder industry gathered in force this past June for PowderMet 2010, the 2010 International Conference on Powder Metallurgy and Particulate Materials.
Stringent NVH requirements, higher
loads and the trend towards miniaturization to save weight and space are forcing transmission gear designers to increasingly tighten the surface finish, bore size and bore-to-face perpendicularity
tolerances on the bores of transmission
gears.
The powder metal (P/M) process is making inroads in automotive transmission applications due to substantially lower costs of P/M-steel components for high-volume production, as compared to wrought or forged steel parts. Although P/M gears are increasingly used in powered hand tools, gear pumps and as accessory components in automotive transmissions, P/M-steel gears are currently in
limited use in vehicle transmission applications. The primary objective of this project was to develop high-strength P/M-steel gears with bending fatigue, impact resistance and pitting fatigue performance
equivalent to current wrought steel gears.
Easily one of the central issues
affecting U.S. manufacturing is what one might call the exports deficit—the inability of American companies to sell products to, for instance, Asian markets, developing countries and other ports of call—due to what they perceive to be unfair trade agreements and or policies.
It’s happened to most manufacturers at one point or another. A defective
product comes back from a customer in
need of repair. Perhaps a bearing or a
gear drive has failed, and the customer
simply needs a replacement. Upon further
examination, the company realizes it was never one of its products in the
first place, but a fabricated copy that
snuck into the market. The manufacturing
community has been dealing with
counterfeit products for decades, but
used machinery dealers and Internet
shoppers seem to continuously get hit
by scam artists.
and process integration.
Imagine the flexibility of having one
machine capable of milling, turning,
tapping and gear cutting with deburring
included for hard and soft material. No, you’re not in gear fantasy land. The technology to manufacture gears on non gear-dedicated, mult-axis machines has existed for a few years in Europe, but has not yet ventured into mainstream manufacturing. Deckel Maho Pfronten, a member of the Gildemeister Group, took the sales plunge this year, making the technology available on most of its 2009 machines.
Non-uniform gear wear changes gear topology and affects the noise performance of a hypoid gear set. The
aggregate results under certain vehicle driving conditions could potentially result in unacceptable vehicle noise performance in a short period of time. This paper presents the effects of gear surface parameters on gear wear and the measurement/testing methods used to quantify the flank wear in laboratory tests.
This presentation is an expansion of a previous study (Ref.1) by the authors
on lapping effects on surface finish and transmission errors. It documents
the effects of the superfinishing process on hypoid gears, surface finish and transmission errors.
A net-shaped metal forming process has been developed for manufacturing quality, durable, high-yield and cost-efficient gears for high-volume production.
An experimental effort has been conducted on an aerospace-quality helical gear train to investigate the thermal behavior of the gear system. Test results from the parametric studies and the superfinishing process are presented.
With reference to the machining of an involute spur or helical gear by the hobbing process, this paper suggests a new criterion for selecting the position of the hob axis relative to the gear axis.
Due to its economical efficiency, the gear shaving process is a widely used process for soft finishing of gears. A simulation technique allows optimization of the process.
The GS:TE-LM thread grinder from Drake Manufacturing is fitted with a robot load/unload system that provides maximum throughput for high-volume production of ground threads.
For more than 22 years, I've been dropping rocks down the well of the gear industry's public opinion. Most every issue, I drop another rock. Sometimes I think I hear a faint splash, but most times I just wait.
Gear Technology was founded 22 years ago on a very simple principle: to provide the best possible educational articles and information for the gear industry.
Guidelines are insurance against mistakes in the often detailed work of gear manufacturing. Gear engineers, after all, can't know all the steps for all the processes used in their factories.
Powder metallurgy (P/M) techniques have proven successful in displacing many components within the automobile drive train, such as: connecting rods, carriers, main bearing caps, etc. The reason for P/M’s success is its ability to offer the design engineer the required mechanical properties with
reduced component cost.
properties.
Flexibility and productivity are the keywords in today’s grinding operations. Machines are becoming
more flexible as manufacturers look
for ways to produce more parts at a
lower cost. What used to take two
machines or more now takes just one.
Recent breakthroughs in profile grinding software are helping Anderson Precision Gears and others meet wind power’s insatiable appetite for faster
production of large, high-quality gears.
The seemingly simple process of placing a uniform chamfer on the face ends of spur and helical gears, at least for the aerospace industry, has never been a satisfactory or cost effective process.
To meet the future goals of higher productivity and lower production costs, the cutting speeds and feeds in modern gear hobbing applications have to increase further. In several cases, coated carbide tools have replaced the commonly used high speed steel (HSS) tools.
Load-carrying capacity of gears, especially the surface durability, is influenced by their tooth surface
roughness in addition to their tooth profiles and tooth traces.
The benefits of ground gears are well known. They create less noise, transmit more power and have longer lives than non-ground gears. But grinding has always been thought of as an expensive process, one that was necessary only for aerospace or other high-tech gear manufacturing.
Almost any external tooth form that is uniformly spaced around a center can be hobbed. Hobbing is recognized as an economical means of producing spur and helical gears with involute tooth profiles.
Economic production is one of the main concerns of any manufacturing facility. In recent years, cost increases and tougher statutory requirements have increasingly made cutting fluids a problematic manufacturing and cost factor in metalworking. Depending on the cutting fluid, production process and supply unit, cutting-fluid costs may account for up to 16% of workpiece cost. In some cases, they exceed tool cost by many times (Ref. 1). The response by manufacturers is to demand techniques for dry machining (Ref. 2).
In recent years, the demands for load capacity and fatigue life of gears constantly increased while weight and volume had to be reduced. To achieve those aims, most of today's gear wheels are heat treated so tooth surfaces will have high wear resistance. As a consequence of heat treatment, distortion unavoidably occurs. With the high geometrical accuracy and quality required for gears, a hard machining process is needed that generates favorable properties on the tooth surfaces and the near-surface material with high reliability.
Crown gearings are not a new type of gear system. On the contrary, they have been in use since very early times for various tasks. Their earliest form is that of the driving sprocket, found in ancient Roman watermills or Dutch windmills. The first principles of gear geometry and simple methods of production (shaper cutting) were developed in the 1940s. In the 1950s, however, crown gears' importance declined. Their tasks were, for example, taken over by bevel gears, which were easier to manufacture and could transmit greater power. Current subject literature accordingly contains very little information on crown gears, directed mainly to pointing out their limitations (Ref. 1).
Recent trends in gear cutting technology have left process engineers searching for direction about which combination of cutting tool material, coating, and process technology will afford the best quality at the lowest total cost. Applying the new technologies can have associated risks that may override the potential cost savings. The many interrelated variables to be considered and evaluated tend to cloud the issue and make hobbing process development more difficult.
The implementation of powder metal (PM)components in automotive applications increases continuously, in particular for more highly loaded gear components like synchromesh mechanisms. Porosity and frequently inadequate material properties of PM materials currently rule out PM for automobile gears that are subject to high loads. By increasing the density of the sintered gears, the mechanical properties are improved. New and optimized materials designed to allow the production of high-density PM gears by single sintering may change the situation in the future.
This report presents some interim results from an ongoing project being performed by INFAC, the Instrumented Factory for Gears. The purposes of this initial phase of the project were to demonstrate the feasibility of robotic automated deburring of aerospace gears, and to develop a research agenda for future work in that area.
Nowadays, finish hobbing (which means that there is no post-hobbing gear finishing operation) is capable of producing higher quality gears and is growing in popularity.
Quality gear manufacturing depends on controlled tolerances and geometry. As a result, ferritic nitrocarburizing has become the heat treat process of choice for many gear manufacturers. The primary reasons for this are:
1. The process is performed at low temperatures, i.e. less than critical.
2. the quench methods increase fatigue strength by up to 125% without distorting. Ferritic nitrocarburizing is used in place of carburizing with conventional and induction hardening.
3. It establishes gradient base hardnesses, i.e. eliminates eggshell on TiN, TiAIN, CrC, etc.
In addition, the process can also be applied to hobs, broaches, drills, and other cutting tools.
Powder metal. To gear makers today, the phrase conjures images of low power applications in non-critical systems. As powder metal technology advances, as the materials increase in density and strength, such opinions are changing. It is an ongoing, evolutionary process and one that will continue for some time. According to Donald G. White, the executive director of the Metal Powder Industries Federation, in his State-of-the-P/M Industry - 1999 report. "The P/M world is changing rapidly and P/M needs to be recognized as a world-class process - national, continental and even human barriers and prejudices must be eliminated - we must join forces as a world process - unified in approach and goals."
The grinding of gears with dish wheels (Maad type grinding machines) is widely viewed as the most precise method of gear grinding because of the very short and simple kinematic links between the gear and the tool, and also because the cutting edges of the wheels represent planar surfaces. However, in this grinding method, depending on the parameters of the gears and one of the adjustments (such as the number of teeth encompassed by the grinding wheels), so-called overtravel at the tip or at the root of the teeth being ground generally occurs. When this happens, machining with only one wheel takes place. As a result, the profile error and the length of the generating path increases while productivity decreases.
The cutting tool industry has undergone some serious changes in the last couple of years in both technology and the way the industry does business. The emerging technology today, as well as for the foreseeable future, is dry cutting, especially in high volume production settings. Wet cutting continues to be as popular as ever with lubrication advances making it more economical and environmentally friendly. There has also developed a process called "near dry cutting." this process offers many of the benefits of fluids while eliminating many of hte associated problems.
I'd like to share with you a vision of the future. It takes place in cyberspace, and it's coming soon to a computer near you. Whether you like it or not, and whether you're ready or not, the Internet is changing the way business is conducted.
Gear noise associated with tooth surface topography is a fundamental problem in many applications. Operations such as shaving, gear grinding and gear honing are usually used to finish the gear surface. Often, gears have to be treated by a combination of these operations, e.g. grinding and honing. This is because gear honing operations do not remove enough stock although they do create a surface lay favorable for quiet operation. See Fig. 1 for typical honing process characteristics. Gear grinding processes, on the other hand, do remove stock efficiently but create a noisy surface lay.
the gear industry is awash in manufacturing technologies that promise to eliminate waste by producing gears in near-net shape, cut production and labor costs and permit gear designers greater freedom in materials. These methods can be broken down into the following categories: alternative ways to cut, alternative ways to form and new, exotic alternatives. Some are new, some are old and some are simply amazing.
For over 50 years, grinding has been an accepted method of choice for improving the quality of gears and other parts by correcting heat treat distortions. Gears with quality levels better than AGMA 10-11 or DIN 6-7 are hard finished, usually by grinding. Other applications for grinding include, but are not limited to, internal/external and spur/helical gear and spline forms, radius forms, threads and serrations, compressor rotors, gerotors, ball screw tracks, worms, linear ball tracks, rotary pistons, vane pump rotators, vane slots, and pump spindles.
We are all looking for ways to increase production without sacrificing quality. One of the most cost-effective ways is by improving the substrate material of your hob. Solid carbide hobs are widely used in many applications throughout the world. LMT-Fette was the first to demonstrate the use of solid carbide hobs in 1993 on modern high-speed carbide (HSC) hobbing machines. Since then the process of dry hobbing has been continuously improving through research and product testing. Dry hobbing is proving to be successful in the gear cutting industry as sales for dry hobbing machines have steadily been rising along with the dramatic increase in sales of solid carbide hobs.
In our last issue, we covered the basic principles of gear shaving and preparation of parts for shaving. In this issue, we will cover shaving methods, design principles and cutter mounting techniques.
I sat down to write this editorial about my father, Harold Goldstein, as he approached his 80th birthday in October. I had meant it to be a celebration of his nearly 65 years in the machine tool business. Unfortunately, on August 26, as I was working on it, my father passed away after a long battle with emphysema. This editorial has now become a memorial as well as a celebration.
Gear shaving is a free cutting gear finishing operation which removes small amounts of metal from the working surfaces of gear teeth. Its purpose is to correct errors in index, helix angle, tooth profile and eccentricity.
It isn't for everyone, but...
Long-time readers of these pages will know that I have always felt strongly about the subject of professional education. There's nothing more important for an individual's career development than keeping up with current technology. likewise, there's nothing more important that a company can do for itself and it employees than seeing to it they have the professional education they need. Giving people the educational tools they need to do their jobs is a necessary ingredient for success.
Broaching is a process in which a cutting tool passes over or through a part piece to produce a desired form. A broach removes part material with a series of teeth, each one removing a specified amount of stock.
It takes confidence to be the first to invest in new manufacturing technology. But the payback can be significant. That has been the experience at the Ford Motor Company's Transmission & Chassis Division plant at Indianapolis, IN, which boasts the world's first production application of dry hobbing.
The chamfering and deburring operations on gear teeth have become more important as the automation of gear manufacturing lines in the automotive industry have steadily increased. Quieter gears require more accurate chamfers. This operation also translates into significant coast savings by avoiding costly rework operations. This article discusses the different types of chamfers on gear teeth and outlines manufacturing methods and guidelines to determine chamfer sizes and angles for the product and process engineer.
Powder metallurgy (P/M) is a precision metal forming technology for the manufacture of parts to net or near-net shape, and it is particularly well-suited to the production of gears. Spur, bevel and helical gears all may be made by made by powder metallurgy processing.
Earlier this year, a relative of mine, Sidney Mandell, tragically passed away. I had the good fortune to serve with Sidney on the Board of Directors and the Executive Committee of the Machinery Dealers National Association (MDNA). Though he started before me, his MDNA career and mine overlapped for about 2 years. As I think back on the many things I learned form him, one of his favorite phrases keeps come to mind: "We walk in the footsteps of those who have gone before us."
As part of the Addendum Team's never-ending quest to improve the overall cultural tone of the gear industry, we bring you the following: April 23 is the 432nd birthday of William Shakespeare.
Increasingly gear designers and product engineers are capitalizing on the economic advantages of powder metallurgy (P/M) for new and existing gear applications. Powder metal gears are found in automobiles, outdoor power equipment transmissions and office machinery applications as well as power hand tools, appliances and medial components.
Surface-hardened, sintered powder metal gears are increasingly used in power transmissions to reduce the cost of gear production. One important problem is how to design with surface durability, given the porous nature of sintered gears. Many articles have been written about mechanical characteristics, such as tensile and bending strength, of sintered materials, and it is well-known that the pores existing on and below their surfaces affect their characteristics (Refs. 1-3). Power transmission gears are frequently employed under conditions of high speed and high load, and tooth surfaces are in contact with each other under a sliding-rolling contact condition. Therefore it is necessary to consider not only their mechanical, but also their tribological characteristics when designing sintered gears for surface durability.
Chicago- Results of recent studies on residual stress in gear hobbing, hobbing without lubricants and heat treating were reported by representatives of INFAC (Instrumented Factory for Gears) at an industry briefing in March of this year.
In today's industrial marketplace, deburring and chamfering are no longer just a matter of cosmetics. The faster speeds at which transmissions run today demand that gear teeth mesh as smoothly and accurately as possible to prevent premature failure. The demand for quieter gears also requires tighter tolerances. New heat treating practices and other secondary gear operations have placed their own set of demands on manufacturers. Companies that can deburr or chamfer to these newer, more stringent specifications - and still keep costs in line - find themselves with a leg up on their competition.
Gear grinding is one of the most expensive and least understood aspects of gear manufacturing. But with pressures for reduced noise, higher quality and greater efficiency, gear grinding appears to be on the rise.
Near-net gear forging today is producing longer life gears at significantly lower costs than traditional manufacturing techniques. Advances in forging equipment, controls and die-making capability have been combined to produce commercially viable near-net-shape gears in diameters up to 17" with minimum stock allowances. These forged gears require only minimal finishing to meet part tolerance specifications.
Gearing for Munchkins
Gene Kasten, president of Repair Parts, Inc., of Rockford, IL, is the proud owner of a miniature Barber-Colman hobber, the only one of its kind in the world. The machine, a replica of the old B-C "A" machine, was built between 1933 and 1941 by W. W. Dickover, who devoted 2, 640 hours of his spare time to the project.
Ausforming, the plastic deformation of heat treatment steels in their metastable, austentic condition, was shown several decades ago to lead to quenched and tempered steels that were harder, tougher and more durable under fatigue-type loading than conventionally heat-treated steels. To circumvent the large forces required to ausform entire components such as gears, cams and bearings, the ausforming process imparts added mechanical strength and durability only to those contact surfaces that are critically loaded. The ausrolling process, as utilized for finishing the loaded surfaces of machine elements, imparts high quality surface texture and geometry control. The near-net-shape geometry and surface topography of the machine elements must be controlled to be compatible with the network dimensional finish and the rolling die design requirements (Ref. 1).
For environmental and economic reasons, the use of coolant in machining processes is increasingly being questioned. Rising coolant prices and disposal costs, as well as strains on workers and the environment, have fueled the debate. The use of coolant has given rise to a highly technical system for handling coolant in the machine (cooling, filtering) and protecting the environment (filter, oil-mist collector). In this area the latest cutting materials - used with or without coolant - have great potential for making the metal-removal process more economical. The natural progression to completely dry machining has decisive advantages for hobbing.
Flute Index
The Hobbing Process
Our company manufactures a range of hardened and ground gears. We are looking into using skiving as part of our finishing process on gears in the 4-12 module range made form 17 CrNiMO6 material and hardened to between 58 and 62 Rc. Can you tell us more about this process?
Most gear cutting shops have shelves full of expensive tooling used in the past for cutting gears which are no longer in production. It is anticipated that these cutters will be used again in the future. While this may take place if the cutters are "standard," and the gears to be cut are "standard," most of the design work done today involves high pressure angle gears for strength, or designs for high contact ratio to reduce noise. The re-use of a cutter under these conditions requires a tedious mathematical analysis, which is no problem if a computer with the right software is available. This article describes a computerized graphical display which provides a quick analysis of the potential for the re-use of shaving cutters stored in a computer file.
CNC technology offers new opportunities for the manufacture of bevel gears. While traditionally the purchase of a specific machine at the same time determined a particular production system, CNC technology permits the processing of bevel gears using a wide variety of methods. The ideological dispute between "tapered tooth or parallel depth tooth" and "single indexing or continuous indexing" no longer leads to an irreversible fundamental decision. The systems have instead become penetrable, and with existing CNC machines, it is possible to select this or that system according to factual considerations at a later date.
The scope of blanking is:
To remove the excess material
Following is the second part of an article begun in our last issue. The first part covered basic shot peening theory, shot peening controls, and considerations that should go into developing a shot peening specification. Part II covers optional peening methods and the relationship of shot peening specifications to the drawings.
Shot peening is widely recognized as a prove, cost-effective process to enhance the fatigue characteristics of metal parts and eliminate the problems of stress corrosion cracking. Additional benefits accrue in the areas of forming and texturizing. Though shot peening is widely used today, the means of specifying process parameters and controlling documents for process control are not widely understood. Questions regarding shot size, intensity, and blueprint specification to assure a high quality and repeatable shot peening process are continually asked by many design and materials engineers.
This article should answer many of the questions frequently asked by engineering professionals and to further assist companies interested in establishing a general shot peening specification.
Dear Editor:
The following article is a collection of data intended to give the reader a general overview of information related to a relatively new subject within the gear cutting industry. Although carbide hobbing itself is not necessarily new, some of the methods and types of application are. While the subject content of this article may be quite broad, it should not be considered all-inclusive. The actual results obtained and the speeds, feeds, and tool life used in carbide hobbing applications can vary significantly.
Beginning with our next issue, some of the promised changes in format for Gear Technology will begin showing up in these pages. As part of our commitment to provide you with important information about the gear and gear products industry, we are expanding our coverage. In addition to continuing to publish some of the best results of gear research and development throughout the world, we will be adding special columns covering vital aspects of the gearing business.
Traditional methods of manufacturing precision gears usually employ either hobbing or shaper cutting. Both of these processes rely upon generating the conjugate tooth form by moving the work-piece in a precise relation to the tool. Recently, attention has been given to forming gear teeth in a single step. Advantages to such a process include reduced production time, material savings, and improved performance characteristics. Drawbacks include complicated tool designs, non-uniformity of gears produced throughout the life of the tooling, and lengthy development times.
Cutter Sharpening
Gear shaping is one of the most popular production choices in gear manufacturing. While the gear shaping process is really the most versatile of all the gear manufacturing methods and can cut a wide variety of gears, certain types of gears can only be cut by this process. These are gears closely adjacent to shoulders; gears adjacent to other gears, such as on countershafts; internal gears, either open or blind ended; crown or face gears; herringbone gears of the solid configuration of with a small center groove; rack; parts with filled-in spaces or teeth, such as are used in some clutches.
After shaping or hobbing, the tooth flanks must be either chamfered or duburred. Here it is paramount that the secondary burr produced will not be formed into the flank, but to the face of the gear, because during hardening, the secondary burr will straighten up and, due to its extreme hardness, will lead to excessive tool wear.
Profitable hard machining of tooth flanks in mass production has now become possible thanks to a number of newly developed production methods. As used so far, the advantages of hard machining over green shaving or rolling are the elaborately modified tooth flanks are produced with a scatter of close manufacturing tolerances. Apart from an increase of load capacity, the chief aim is to solve the complex problem of reducing the noise generation by load-conditioned kinematic modifications of the tooth mesh. In Part II, we shall deal with operating sequences and machining results and with gear noise problems.
This article deals with certain item to be taken into consideration for gear grinding, common problems that arise in gear grinding and their solutions. The discussion will be limited to jobbing or low-batch production environments, where experimental setup and testing is not possible for economic and other reasons.
Hobbing is a continuous gear generation process widely used in the industry for high or low volume production of external cylindrical gears. Depending on the tooth size, gears and splines are hobbed in a single pass or in a two-pass cycle consisting of a roughing cut followed by a finishing cut. State-of-the-art hobbing machines have the capability to vary cutting parameters between first and second cut so that a different formula is used to calculate cycle times for single-cut and double-cut hobbing.
Why Brushes?
In this age of hi-tech, robots, automatic machines, machining cells, etc., is there a niche somewhere for power brushes? Let me answer by asking another question. What tool does the gear manufacturer have in his arsenal that allows him to deburr green gears, hardened gears, hobbed gears, ground gears and shaved gears? What tool allows him to deburr powder metal gears - green and sintered - brass gears, bronze gears, stainless gears made of exotic materials such as inconel, waspaloy, or hastaloy, and fiber and plastic gears? How about spur gears, helical gears, sprockets, both internal and external splines, clutch teeth and pump gears?
In 1985 a new tooling concept for high volume gear production was introduced to the gear manufacturing industry. Since then this tool, the wafer shaper cutter, has proven itself in scores of applications as a cost-effective, consistent producer of superior quality parts. This report examines the first high-production installation at the plant of a major automotive supplies, where a line of twenty shapers is producing timing chain sprockets.
This article investigates fillet features consequent to tooth grinding by generating methods. Fillets resulting from tooth cutting and tooth grinding at different pressure angles and with different positions of grinding wheel are compared. Ways to improve the final fillet of the ground teeth with regard to tooth strength and noise, as well as the grinding conditions, are shown. "Undergrinding" is defined and special designs for noiseless gears are described.
Consisting of only a ring gear b meshing with one or two planets a, a carrier H and an equal velocity mechanism V, a KHV gearing(Fig. 1) is compact in structure, small in size and capable of providing a large speed ratio. For a single stage, its speed ratio can reach up to 200, and its size is approximately 1/4 that of a conventional multi-stage gear box.
Almost all machines or mechanical systems contain precision contact elements such as bearings, cams, rears, shafts, splines and rollers. These components have two important common requirements: first, they must possess sufficient mechanical properties, such as, high hardness, fatigue strength and wear resistance to maximize their performance and life; second, they must be finished to close dimensional tolerances to minimize noise, vibration and fatigue loading.
The quality of the finished gear is influenced by the very first machining operations of the blank. Since the gear tooth geometry is generated on a continuously rotating blank in hobbing or shaping, it is important that the timed relationship between the cutter and workpiece is correct. If this relationship is disturbed by eccentricities of the blank to its operating centerline, the generated gear teeth will not be of the correct geometry. During the blanking operations, the gear's centerline and locating surfaces are established and must be maintained as the same through the following operations that generate the gear teeth.
NC and CNC metal cutting machines are among the most popular machine tools in the business today, There is also a strong trend toward using flexible
machining centers and flexible manufacturing systems. The same trend is apparent in gear cutting. Currently the trend toward CNC tools has increased, and sophisticated controls and peripheral equipment for gear cutting machines are now available; however, the investment in a CNC gear machine has to be justified on the basis of economic facts as well as technical advantages.
Since we are a high volume shop, we were particularly interested in Mr. Kotlyar's article describing the effects of hob length on production efficiency which appeared in the Sept/Oct issue of Gear Technology. Unfortunately, some readers many be unnecessarily deterred from applying the analysis to their own situations by the formidabilty of the mathematical calculations. I am making the following small suggestion concerning the evaluation of the constant terms.
shafts.
the same heat of material
One of the current research
The gear hobbing process is a generating type of production operation. For this
reason, the form of the hob tooth is
always different from the form of the
tooth that it produces.
techniques.
A recent U.S. Army Tank-Automotive Command project, conducted by Battelle's Columbus Laboratories. successfully developed the methodology of CAD/CAM procedures for manufacturing dies (via EDM) for forging spiral bevel gears. Further, it demonstrated that precision forging of spiral bevel gears is a practical production technique.
Although no detailed economic evaluation was made in this study, it is expected that precision forging offers an attractive alternative to the costly gear cutting operations for producing spiral bevel gears.
A gear can be defined as a toothed wheel which, when meshed with another toothed wheel with similar configuration, will transmit rotation from one shaft to another. Depending upon the type and accuracy of motion desired, the gears and the profiles of the gear teeth can be of almost any form.
