Imagine the flexibility of having one
machine capable of milling, turning,
tapping and gear cutting with deburring
included for hard and soft material. No, you’re not in gear fantasy land. The technology to manufacture gears on non gear-dedicated, mult-axis machines has existed for a few years in Europe, but has not yet ventured into mainstream manufacturing. Deckel Maho Pfronten, a member of the Gildemeister Group, took the sales plunge this year, making the technology available on most of its 2009 machines.
What do glam and avant garde rock star Brian Eno, AGMA and Seattle Gear Works have in common? Admittedly, not much. But there is a connection of sorts.
