Given the current economic and legal climate, matters of hiring and firing are cause for considerable concern among managers. In addition to all the other factors to be considered, employers must be wary of exactly how these procedures should be carried out, so that the company is not left open to lawsuits based on charges of discrimination of one kind or another. The reasons given for a particular employment decision may be as crucial to determining liability as the decision itself.
Have you ever been confronted by a thorny business problem, only to discover - belatedly - that it has been creeping up on you for months, or even years?
The acceptance by discerning customers of passenger cars is dependent upon both the actual noise lever and the subjective noise character.
The subjective noise character itself can contain, among other features, undesirable noise phenomena which become apparent at certain points in the vehicle operating range. One such critical phenomenon is gear rattle, which is mainly present under low speed, high load conditions. Due to changes in the angular velocity of the crankshaft, gear rattle under driving conditions occurs at the unloaded gears and splines.
8 Gear Technology advertisers will have booths at IMTS 92, the largest trade show in the Western Hemisphere. The show opens in Chicago on Sept. 9 and runs through the 17th. More than 800 companies from around the world will cover some 931,000 sq. ft. of exhibit space to show the latest manufacturing technology - everything from forming and fabrication products to environmental and plant safety equipment.
"Opportunity is the start of great enterprises." said the Greet statesman Demosthenes, and what was true 2300 years ago is no less true now. Plenty of opportunities which can grow into great - and successful - enterprises are waiting for us right now if we only have the foresight to take advantage of them.
The whole point of a trade show is to get leads that will turn into sales. No matter how attractive your booth was, no matter how smoothly the setup and the show ran, no matter how many visitors you had at your booth, if your presence at a show didn't net you any sales, then your considerable investment of time, money, and effort has been wasted.
