should be considered.
stress will be discussed.
While the two have taught a variety of AGMA courses over
the years, without question their most popular courses are
Gear Failure Analysis (Errichello with longtime colleague Jane
Muller) and Gearbox CSI: Forensic Analysis of Gear & Bearing
Failures (Drago). Drago currently teaches Manufacturing &
Inspection (with AGMA instructor Joseph W. Lenski, Jr.) and
Gearbox System Design: The Rest of the Story - Everything but
the Gears and Bearings (with AGMA instructor Steve Cymbala)
as well.
IMTS, held bi-annually here in Chicago, ended September
17. It was the third-largest IMTS ever, both in terms of registrations
(115,612) and exhibit space occupied (1,370,256 square
feet). Also, this year's show had more exhibiting companies
(2,407) than any previous IMTS.
