When designing gears, the engineer is often faced with the problem of selecting the number of teeth in each gear, so that
the gear train will provide a given speed ratio
1984 by the author
The contact lines of a pair of helical gears move diagonally on the engaged tooth faces and their lengths consequently vary with the rotation of the gears.
The manufacturing quality of spiral bevel gears has achieved a very high standard. Nevertheless, the understanding of the real stress conditions and the influences. of certain parameters is not satisfactory.
High speed gearing, operating with low viscosity lubricants, is prone to a failure mode called scoring. In contrast
to the classic failure modes, pitting and breakage, which generally take time to develop, scoring occurs early in the
operation of a gear set and can be the limiting factor in the gear's power capability.
Much information has been written on gear inspection, analytical. functional. semiautomatic and automatic. In most
cases, the charts, (if you are lucky enough to have recording
equipment) have been explained.
